Home > Technical (L322) > have i got all the sat nav bits |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
ive just brought a job lot of sat nav parts for the ff and i just wanted to check that ive brought everything i need other than the loom.....
18th Apr 2011 1:13pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35259 |
gps antenna?
18th Apr 2011 1:16pm |
ill check with him and see if the antenna is included...as for the how to ive got to source that for myself...thanks scarey "RANGEISM WILL NOT BE TOLERATED"
18th Apr 2011 1:22pm |
The speed signal is taken from the ABS ECU, how it interfaces I'm not sure. Rave will tell you which data bus it goes through. |
18th Apr 2011 6:20pm |
brilliant thanks guys.....the bloke said that everything i need is there apart from the loom so ill have to ask him if the speed things there as well if not ill have to run it off of standard gps for now..
18th Apr 2011 6:58pm |
ok ive just got a messege back with a list of parts that im getting so not all the bits i was after are there
19th Apr 2011 10:05am |
can you not use your existing amp .. ... - .- -.
19th Apr 2011 10:20am |
....and ,it might be worth considering this option.
19th Apr 2011 10:22am |
maybe ill be able to use my amp im not sure....i dont like or get what his done there as he allready had nav ...but each to there own i suppose if i went the aftermarket route i would have gone for the units they sell that look just like the oem sat nav but im really after the real deal as it just looks right and allows me to keep my multi changer "RANGEISM WILL NOT BE TOLERATED"
19th Apr 2011 10:32am |
has anyone on here retrofitted a sat nav if so does anyone have a link to the thread as ive searched but cant seem to find it.... "RANGEISM WILL NOT BE TOLERATED"
20th Apr 2011 11:37am |
Seems to me there was a song in the 70's: 'Will it go round in circles'
You might want to re-read your old thread - it's all there: http://www.fullfatrr.com/forum/topic4784.html?highlight=satnav Quoting myself from your thread:
To get the system up and running you need: - the monitor - the nav computer - the radio module - a gps antenna (can be universal auto unit sold on ebay for Audi, BMW, etc- but must be waterproof) - a wiring harness You don't need either of the amps - it will be the equivalent of your present system w/o. I assume someone has offered you the lot for GBP150 or the like? Make sure you don't wind up with: - a monitor that has issues - they're not hard to come by so this is less of a prob - a tv module for a 4:3 screen - newer ones can be coded for 16:9 by unsoldering and reprogramming an eprom, older ones can't - a mkIII nav computer with a bum laser (the norm more than a good laser) - a radio unit with one or more channels gone (also the norm) These bits are relatively dear when in good shape - as the problems they have are not uncommon so they are sought after replacement parts. And what are you going to do for a harness? Get back to me if you need help... The Alpine system that Scarey linked to cost over $2000... To each his own is right. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
20th Apr 2011 12:36pm |
hi steve thanks for your help ive managed to get the lot for £300 but there is no amp and no harness ...i knew i had spoke before about this but could not for the life of me find the thread so thanks "RANGEISM WILL NOT BE TOLERATED"
20th Apr 2011 2:45pm |
Yaa, dunno why, but search don't work so good here...
20th Apr 2011 9:03pm |
great how much £££ also are you sure my amp will be fine ....im sure i have an amp here is the pic of whats in the rear nearside panel of my hse
20th Apr 2011 9:30pm |
