Home > My Range Rover > L322 Vogue 2005 4.4 v8
Sigmundreder
Norway 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
Hello!
My name is Sigmund, and i recently bought my first Range Rover.
This is my third Land Rover, having previously owned a 2006 Defender 110 TD5 for six years, and i 1998 Discovery 1 300 tdi auto for a couple of months.
I loved my Defender (and hated the Disco…), but now it was time for some comfort.
The whole family was split between a Disco 3/4 or a L322.
We have a gundog, so a large boot is needed. But in the end, we thought that a «full fat» was what we wanted the most.
The car we bought a Vogue 4.4 V8 Petrol in Buckingham Blue, with blue interior.
Bought at 199.500 km on the clock.
Has a great service history and only three prior owners.
So far i have:
- Changed the side bezels from chrome to grey
- New lettering on the tailgate
- Changed white side repeators to orange
- Flushed and cleaned the rear wiper nozzle
- New oil and filter
- Pollen filter
- Air filter
- Messed up, and trying to fix the headlight wipers.
- New rear right sidelight as the old was leaking and fogging up badly.
- Remowed the old Siemens phone docking in cubby.
The plan is to keep the car stock with no bling, and sorting out the last minor thing, and keep it in the good Shape this car deserves.
Things i need to sort out:
- I need different small interior fixings all around (not to worring)
- Left side headlight wiper is not good (tried fuse 19 reset)
- Some problems with the FBH
- New studded Winter tyres, got two sets of rims (20’’ and 18’’)
- Westfalia removable tow hitch is stuck
- Heater matrix fan is not shutting up
- Minor oil leaks, not sure from where yet.
- New petrol filter
- Flushing coolant (heard that bleeding on the V8 is not very easy).
But we are super happy with the car, and almost everything is working the way it should!
Will keep posting here Smile
//Sigmund
Post #607681 29th Sep 2021 12:30pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Welcome Sigmund and great to see L322 around the world Thumbs Up
Post #607682 29th Sep 2021 12:42pm
Sigmundreder
Thank you!
I forgot to say that wheel archers are looking good, and that mid october i have an appointment to drench the underside in Fluid film (which is incredible!).
We got a lot of salt on the roads here in Norway, so that is something i do with all my cars once every year.
If you are looking for the best rust protection, check out Fluid film!
Its lanolinbased.
Post #607683 29th Sep 2021 12:52pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
looks good RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #607693 29th Sep 2021 1:18pm
Sigmundreder
And.. the handbrake does not work, at all.
I really hope that i can get away with just adjusting it, but i think i will need some parts
Post #607770 30th Sep 2021 9:41am
Sigmundreder
For those interested, i have som problems with my FBH/Webasto.
Made a thread here:
https://www.fullfatrr.com/forum/post607882.html#607882
Will try disconnect the unit in the near future.
Post #607884 1st Oct 2021 5:14pm
Sigmundreder
Made a thread here:
Post #607885 1st Oct 2021 5:15pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Hello Sigmund and welcome!
Here's some advice:
Check on Ebay, no need to be brand new. Supertwraks and similar sites (although UK based) are also a good source.
Iirc it's fuse 38. But still, it's probably the washer pump that's burned. There are inexpensive Hella ones on sale anywhere you look at. These are not high pressure, that's why they are cheap.
Wish mine had one...
18" would be for my "working" tyres
Guess some penetrating oil would help...
Look up FSR final stage resistor. It's around 50 euros part on Ebay; not too hard DIY fit
Check the rocker cover gaskets, spark plug wells, VANOS solenoid seals and upper timing chain cover gaskets. Better tackle all these in one go. Quite inexpensive, really. And consider bead blasting + powder coating the rocker covers EXTERIOR while at it Thumbs Up
Look up and check the cyclonic oil separator, PCV valve and the associated fittings and hoses. Inspect and replace the thin tubes running from the PCV valve and branching over the intake manifold. They cost next to nothing.
A vacuum leak may be hard to track down and cause a ton of unexplained symptoms but it is easily remedied or prevented.
- New petrol filter
Easy one
- Flushing coolant (heard that bleeding on the V8 is not very easy). Bleeding is VERY easy, it will bleed out by itself at the slightest opportunity Rolling with laughter
Seriously now, have the hoses checked. Mine had suffered mostly hoses and rubber fitting failures...
Whatever you do, use only ONE type of coolant EITHER Green OR Red.
The valley pan is another weak spot which can fail quite impressively but you can't know it's gone bad until it eventually fails. Not the end of the world by any means...
Consider changing front+rear diff oils plus transfer case oil (not urgently)
Do change gearbox fluid. Will need about 7 ltrs for a simple change not a flush. Buy original JLR filter + gasket. As for the oil, you can pay JLR ticket at the tune of 30+ euros / ltr OR use fuchs TITAN ATF1 or Fuchs ATF 4000. The latter will happily replace your power steering fluid as well. Those are af 14 euros / ltr Thumbs Up
PS : I love how you can fit a large cage and secure it with the buckle straps. Mine came with a pair of factory ones plus a cargo net! I'm sure your gun dog enjoys the ride in that cozy cabin.
Post #608019 3rd Oct 2021 10:44am
Sigmundreder
Post #608493 6th Oct 2021 4:54pm
Sigmundreder
Finally got Westfalia off, cleaned and lubed and tucked away!
Needs to go on already this weekend, but now it dont need to be on all the time.
Was more of a patience game, then brut force.
Post #608494 6th Oct 2021 5:01pm
vs322
Thumbs Up WD40 and a rubber mallet are (your) best friends in the L322 ownership experience Whistle
Post #608501 6th Oct 2021 5:29pm
Sigmundreder
Today the car got some really good treatment with FluidFilm, so now i am ready for the extreme amounts of salt they use in here in Oslo, Norway.
This is a job where i use professionals since its a real mess.
As the temperatures drop, i thought about using the heated steering wheel... and suddenly it hos stopped working.
Theres still a lot to do with this car, so i wont address this fault now, but it would be really nice to have during the colder months.
But, the ride is beutiful! I dont miss my Defender much Smile
Post #609255 15th Oct 2021 10:23am
