Home > Technical (L322) > Lean Bank 1 and PCV?
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
I've been battling a lean on bank 1 code for a little while now. So far I've (in no particular order):
Had the inlet in pieces and rebuilt with new gaskets from the head up.
Smoke tested the inlet system - No Leaks
Replaced the PCV valve - twice
Sprayed around to check for vacuum leaks
Replaced the O2 sensor, pre-cat.
I have noticed that the PCV seems to flow a lot of air at idle, and the fuel trims seem to indicate that the fueling is out mainly at idle. If I stop the PCV flow at idle, the fuel trims head back towards zero.
Any thoughts? 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #608276 5th Oct 2021 9:01am
As it's just one bank it could be injectors...??
Or possibly the other downstream lambda sensor...?
These are just some guesses Thumbs Up Pete
Post #608278 5th Oct 2021 9:07am
400-ascona
Thanks. Injectors is a possible I guess. However, the car also has LPG and the same issue happens on LPG. Hence I figured it must be air related. The PCV flowing at idle seems to be significant?
I discounted the downstream sensor (post Cat), because I figure that just checks the Cat is operating and has no input to fuel control. 05 L322 4.2SC
Lotus Carlton
Ascona 400
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Post #608290 5th Oct 2021 9:57am
Ah, you didn't mention LPG, if it hasn't had a valve saver fitted, and more importantly, topped up and used, then you maybe suffering from valve seat recession...!
Do a compression test.... Thumbs Up Pete
Post #608308 5th Oct 2021 11:39am
400-ascona
Valve saver by the gallon. Its only done about 15k miles on LPG. Compression test done and no issues. 05 L322 4.2SC
Lotus Carlton
Ascona 400
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Post #608314 5th Oct 2021 12:51pm
dhallworth
Remove your MAF, give it a good soaking with electrical contact cleaner, let it dry and then refit it.
Mine started to occasionally throw a fault and ran a bit lumpy, cleaning the MAF feels like it made a big difference.
For the sake of a £4 tin of contact cleaner it's worth a try Smile
Post #608327 5th Oct 2021 2:25pm
400-ascona
Apologies, should have said, I've cleaned the MAF, twice Embarassed I also assumed it would impact both banks equally, but bank 2 is quite stable on fuel trims. 05 L322 4.2SC
Lotus Carlton
Ascona 400
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Post #608344 5th Oct 2021 4:09pm
400-ascona
I'm reaching the bottom of the barrel now Confused
I'm also selling the Disco 4 this weekend as its currently worth £2000 more than I paid for it 2.5 years ago, so I need the RR sorted so I can tow the caravan. Nothing like a deadline to focus the mind Wink 05 L322 4.2SC
Lotus Carlton
Ascona 400
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Post #608347 5th Oct 2021 4:12pm
dingg1
My money would be on pulling in air on bank 1 somewhere.
Post #608358 5th Oct 2021 5:15pm
400-ascona
I agree. I cant find anything other than high flow through the PCV valve back into the throttle body. If I block that flow, the fuel trims settle back to around zero.
Should the PCV flow at idle? I'm unsure how it is supposed to work. 05 L322 4.2SC
Lotus Carlton
Ascona 400
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Post #608360 5th Oct 2021 5:25pm
dingg1
If its a 4.2 sc, thats where I had major issues getting the hoses that plug into the pcv to seat, its a poor design imo, I ended up removing the pcv and taping up the connectors with self amalgamating tape, it stopped a constant problem I had with vacuum leaks on the system.
Eta it sucks like a crack whore looking for her next fix
Post #608368 5th Oct 2021 6:43pm
400-ascona
Thanks. I had the same problem with the hose. Bought a new one (£120+ !!!!) and that was poor too. Ended up with a "temporary" piece of 22m id hose and a couple of jubilee clips. Not pretty, but sealed!
Fitted second new PCV Monday night. Now just awaiting the light to come back on .......... Whistle
And useful to know it breathes heavy anyway! 05 L322 4.2SC
Lotus Carlton
Ascona 400
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Post #608542 7th Oct 2021 9:17am
400-ascona
So...... a whole week with no EML, and then Sunday morning, on it comes.
The above is the long term fuel trims and the peak on Bank 1 is when I pick the revs up.
Any more suggestions? 05 L322 4.2SC
Lotus Carlton
Ascona 400
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Post #608827 11th Oct 2021 8:26am
dingg1
Do you sometimes have the viscous fan running for what appears to be no reason? Usually just a few minutes after you have just started up?
Or a pending p0116 code?
Post #608829 11th Oct 2021 9:34am
400-ascona
Not at a time which I would say isn't appropriate and the only fault code is the lean on bank1 code (P0171?). In actual fact it is running really well with no issues noticeable. What are you thinking? 05 L322 4.2SC
Lotus Carlton
Ascona 400
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Post #608911 12th Oct 2021 8:15am
