Home > Technical (L322) > P R N D S not lighting up
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Twice today the P R N D S red led went out after a drive and didn’t illuminate, then after turning on and starting they came on any ideas 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #608235 4th Oct 2021 7:12pm
Furnitureman
No one had this before 2012 Range Rover Westminster 4.4 TDV8
Post #608324 5th Oct 2021 12:52pm
most anomalies like this tend to be battery related...the battery has a string of ecu's to power up when starting and if the voltage is a bit low then some dont get triggered and bypassed.
a good example are the ciggy/power sockets... ... - .- -.
Post #608326 5th Oct 2021 12:55pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Mines hardly ever worked since I got it 2 year ago. Never bothered me but I can only guess maybe it's just a loose connection of electrical conduction for the red light I guess
Post #608346 5th Oct 2021 3:11pm
Furnitureman
Don’t think it’s battery related as the car had been on a long run so fully charged 2012 Range Rover Westminster 4.4 TDV8
Post #608361 5th Oct 2021 5:07pm
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
I’ve had the same issue for the 3 years I’ve had it, on two occasions when all of the sudden it does light up and work which has been twice in 3 years the rear heated seats start to work ! Someone mentioned that the gear indicator is wired through the fuse for the rear gates seats so I’m guessing it’s a short somewhere. It’s not too difficult to take the centre console off and check for loose wires. Have you checked if your rear heated seats still work when the gear indicator goes off ?
Post #608384 5th Oct 2021 7:31pm
Furnitureman
I’ll test next time I’m out driving 2012 Range Rover Westminster 4.4 TDV8
Post #608482 6th Oct 2021 2:51pm
