![]() | Home > Technical (L322) > 3 gang Pipe clips |
landy95 Member Since: 04 Aug 2021 Location: Hall Green, West Midlands Posts: 79 ![]() ![]() ![]() |
Okay done some more searching, feel slightly foolish as i missed the parts catalogue Microcat in the wiki although i may be using the first microcat-english listed incorrectly as i could see the part but not a number, the last microcat english in the list showed the part number of the triple clip as RYC000110 and they aren't cheap at around £8 each.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1310 ![]() ![]() ![]() |
Have a look at part number SGK000050 mate. |
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 207 ![]() ![]() ![]() |
If that is the rear right side then is the box for tyre pressure sensors or for brake sensor plugs? I had thought the latter, unless there is a similar box close by. |
Im not sure which it is to be honest im sure someone will put us out of our mysery. |
Just checked, its ABS and brake sensor plugs. |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 ![]() ![]() ![]() |
It’s a while since I had these off my TD6 to paint the wheel arches but if I remember correctly they are held on with two fir tree type clips which are moulded to the back of the box and you have to either push or pull a plastic pin from the centre of each plug to remove the box. You should be able to see them with the box lid open and the wires pulled out of the way. As I said though, it’s been a while and I may be thinking of the wrong bit, so sorry if I’m wrong! 2012 Westminster TDV8 4.4 Indus Silver
Thanks for the info. Also own a 1976 Land Rover 101 3.5 V8.
