Home > Technical (L322) > Engine misfire
Penfold0
England 2011 Range Rover Vogue 4.4 V8 Java Black
Engine misfire
Recently bought tdv8 4.4 2011
Engine misfire badly tick over and running speed any clues had injecters checked no faults
No engine lights showing on dash
Not reading any faults on snapon reader
Post #607981 2nd Oct 2021 8:16pm
cass
Blocked cat might be a starting point if there are no codes
Post #608029 3rd Oct 2021 11:47am
Treebor99
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
I don't know for sure but I'd start by checking the basics.
My old Disco 3 started misfiring when the fuel filter needed changing one time - I don't recall there being any error codes.
Air filters? MAF and MAP sensors clean?
Good luck Anything can be made to work if you fiddle with it long enough (and have deep pockets|)
Current cars, 2011 FF 4.4 TVD8; Audit TT 1.8T convertible.
Post #608182 4th Oct 2021 1:46pm
Penfold0
Speaking to land rover specialist and iv bin told to check wiring loom to injecters due to curosion and brittle wires
Post #608211 4th Oct 2021 5:12pm
