Home > Maintenance & Mods (L322) > Jacking the rear
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Jacking the rear
So LR suggest using the rear crossmember to jack the rear of the car, however the exhaust pipes are totally in the way. There's absolutely no way would I get a jack under there unless it was a mega unstable bottle jack.
Anyone else found a way around this?
I need the car up in the air and level to do the gearbox oil.
Post #607842 1st Oct 2021 9:47am
kevinp
I totally agree about the jacking point. When I first got my car I read the manual, got underneath with my jack and thought, Eh??
I've made a set of wooden planks of different heights to put under the wheels because my drive has a gentle slope both ways to get it level for fluid checking.
Post #607843 1st Oct 2021 10:12am
Baltic Blue
Not a cheap solution, but 2 sets of ramps then put car in off road height is the safest solution.
Post #607847 1st Oct 2021 10:34am
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I bought a set of Fiamma Level Up Jumbo. Not bad at only £32.50 for a pair:
http://www.fiammastore.com/Fiamma-Leveller...-Levellers
Post #607853 1st Oct 2021 11:32am
