Home > In Car Electronics (L405) > Speedometer Display
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Speedometer Display
Is there any way to change the speedometer from MPH to KPH? Would have been really useful on my recent trip to France.
Car is a 2013 Vogue SE SDV8
TIA
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #607831 1st Oct 2021 7:52am
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
It’s in the display settings menu.
Post #607832 1st Oct 2021 7:57am
you can also keep the digital display as mph to correspond to the main kph speedo. ... - .- -.
Post #607836 1st Oct 2021 9:00am
I didn't realise you could change the main display - I always just change the digital readout to kph.
Change your high beam assist side at the same time - and your clock - my 3 jobs for the tunnel crossing Very Happy
Post #607840 1st Oct 2021 9:12am
IGP
Thanks for the replies.
OK had a look at the display settings menu and all I have is off road view and torchlight effect, no other options. Nor do I have the digital speed display at the centre bottom of the dash like on my wife's Freelander 2. Am wondering if something needs to be activated using an IID tool.
Post #607851 1st Oct 2021 11:24am
Menu button on the steering wheel ?
Then a menu appears in the middle of the dash, then Instrument display....
Post #607852 1st Oct 2021 11:32am
IGP
Hi Alistair
That's where I went. No other options other than those mentioned.
Thanks
Post #607855 1st Oct 2021 12:03pm
Hmmm - probably not helpful, but this is what mine shows -
Not been altered with an IID tool or anything else - I think it's always been like that.
Post #607856 1st Oct 2021 12:11pm
IGP
OK, I don't have that at all. This is all I have
Thanks 2013 Vogue SE SDV8
Post #607859 1st Oct 2021 12:30pm
is it the same with the engine running Ivan?
its weird that yours and Alistairs are both the same year and both SE.. ... - .- -.
Post #607863 1st Oct 2021 1:29pm
IGP
Hi Stan
Yes, it's the same with the engine running. Will have a poke around with my IID tool over the weekend to see if something has been disabled.
Post #607868 1st Oct 2021 2:41pm
Ivan, your car is a launch spec 2012 build (it has blue rings around the speedo) yours uses the Range Rover logo in the centre of the binnacle, yes?
Alistair, yours is a 13.5/14MY (silver rings around the speedo) yours uses a Land Rover oval badge in the centre of the binnacle, yes?
So, the can-bus on the early model did NOT include the electronic speedo... "I believe it was not finished in time for the release of the 405!" so, there you have it... If you have blue rings and the Range Rover lettering then you wont & cannot use this function... Sorry Bow down Whistle Thumbs Up
Post #607900 1st Oct 2021 9:19pm
IGP
Hi Craig
Thanks very much for the explanation. I just know my car was registered in March 2013 so didn't realise it was a 2012 specification. Would a software update be able to provide the later menu?
Thanks
Post #607912 2nd Oct 2021 7:38am
Yep Nov 2013 for me - well done Craig Thumbs Up
I was wondering about those blue rings & where that was on the settings - had made a note to myself to look for that, but sounds like a feature that can't be changed.
Post #607915 2nd Oct 2021 7:57am
Ivan, alas the canbus on your cars binnacle is different to that of Alistairs car so as far as I know there is NOT a software update to allow this to happen! Changing the binnacle’s could be an option? Maybe? Don’t know anyone who wants to go to that much work/expense to try sir… Thumbs Up
I have been right through this with GAP back 3-4yrs ago and couldn’t do anything sorry sir…
Post #607932 2nd Oct 2021 12:04pm
