![]() | Home > Maintenance & Mods (L322) > Are height sensors sided |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8385 ![]() ![]() ![]() |
IIRC fronts are sided, rears are the same... they don't tend to have one part where they are sloppy when I've removed old ones, you can spin it in your hand and the arm is sloppy on the entire 360 degrees, the new ones are tight and firm... So swapping may work but don't hold your breath...
woodrjh Member Since: 13 Sep 2021 Location: Burgess Hill Posts: 26 ![]() ![]() ![]() |
Can someone confirm if the front height sensors on cars with variable damping are sided?
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
MY10-12 have identical sensors left and right, but different sensors with and without adaptive dynamics, although adaptive ones will work on non-adaptive vehicles (MY10). Your part numbers are correct according to Microcat 2012 version. |
So it looks like my intermittent adaptive suspension failure was the classic loose/broken wire to the top of the front damper.
