Home > Maintenance & Mods (L405) > Full Filter And Fluid Service Done - Nearly
knwatkins
Hi baisong, the filter for the Dynamic Response system is now built in to the reservoir, unlike on the earlier Land Rover systems where the filter was built into the valve block under the vehicle.
So, that's why the service sheets specify to replace the reservoir every 80k miles or 5 years. That's why I replaced it, as per my first post in this thread. It's easy enough to replace, just a few hoses to unclip and a couple of screws to undo.
The fuel filter on a UK spec (RHD) V8 diesel is located on the passenger side, in the engine bay, just below the windscreen and is replaced every 2 years or 32k miles. As for the US spec V8 petrol/gas, I'm not sure but it'll be documented in the service manual, which you can download from the wiki... Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #607634 28th Sep 2021 9:37pm
baisong
United States 2016 Range Rover 5.0 SC V8 Fuji White
May I ask why you changed Dynamic response reservoir? Is the Dynamic response filter in there? Thanks
Post #607635 28th Sep 2021 9:48pm
knwatkins
Yes Kev
Post #607637 28th Sep 2021 9:50pm
baisong
Thanks very much!
Could you please provide a link where to download the service/repair manual? Many thanks
Post #607646 29th Sep 2021 3:59am
knwatkins
https://drive.google.com/open?id=1aSE85XAU...JN27BjS3Pd Kev
Post #607647 29th Sep 2021 5:32am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
knwatkins wrote:
So, my 20 litres of Mannol AG60 turned up this week from Germany and this morning I braved the rain and replaced the fluid in the gearbox.
I always buy my ATF from these guys because their prices are excellent. £72 in this case, including delivery. https://www.motor-oel-guenstig.de/
As we know, due to the majority of fluid residing in the torque converter, only a limited amount of fluid can be drained from the drain hole. In my case, bang on 3 litres.
I ended up draining and refilling the gearbox 4 times. Priming the gearbox in between each fill by:
- Starting the engine and holding my foot on the brake
- Shifting to reverse and holding for 5 to 10 seconds
- Shifting to drive and holding for 5 to 10 seconds
- Shifting to 2nd using the paddle shifter and holding for 5 to 10 seconds
- Shifting to neutral, then releasing the brake and holding the revs at 2000rpm for at least 30 seconds to fully fill the torque converter
Fresh oil is shown at the top. First drain is on the left and fourth drain is on the right. Obviously the oil in the gearbox now will be a shade lighter than the one shown on the right.
I could have done a few more drain and refill cycles because I have about 8 litres of clean fluid left. However, I got a bit too wet in the rain and thought I'd save the fluid for a refresh next summer, when it's a little warmer outside. Very Happy
Hopefully that should keep the gearbox in good nick for a while Thumbs Up
I'm guessing you don't have the ZF 8 speeder then? That oil is about 40 quid a litre.
Post #607668 29th Sep 2021 10:44am
knwatkins
Yes, I the 8 speed ZF is the only gearbox available for the L405.
ZF Lifeguard fluid is expensive, but isn't the only fluid you can use. There are many manufacturers that manufacture the fluid to the specification, just like engine oil. Kev
Post #607680 29th Sep 2021 12:08pm
Caesium
That is worth knowing.
I've just ordered a ZF refresh kit, the sump and 7 litres of oil. Came to £145.
That oil looks much better value though.
Post #607690 29th Sep 2021 1:11pm
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
HI Caesium
For a sump pan and 7L OF zf Lifeguard Fluid8 i think you got a bargain where did you purchase from .
Post #607692 29th Sep 2021 1:18pm
Caesium
154JON wrote:
HI Caesium
Autodoc.
Post #607701 29th Sep 2021 3:02pm
