![]() | Home > Maintenance & Mods (L322) > battery discharging |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2051 ![]() ![]() |
Welcome to FFRR ownership and the good old battery drain |
gimmesunshine Member Since: 17 Apr 2011 Location: dorset Posts: 16 ![]() ![]() ![]() |
i ve got the panels of now to get to the fsr but i am not sure it looks like the posts
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
a very nice bloke by the name of storey has done this write-up
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
When you say it's had a new battery, is it a genuine LR one or aftermarket? The one that should be fitted is huge and it's a really common mistake to fit the smaller/ incorrect batt. My Previous RR's!
its a bosch 120A, so its quite large, not sure what it should be
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Sounds like you're lucky with the PO. I think the Orange Led probably relates to the lock which you can apply to the rear window switches, so quite normal. Also I think the touchscreen remains on when you lock the car, for a little while. In all, probably little or no problems, you may have a battery discharge issue I suppose, not unknown in the Range Rover, but fingers crossed for you! 2012 SDV8 Vogue SE |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 ![]() ![]() |
Know the feeling, did the same today - left the radio on for 1hr max while giving it a quick clean and the battery was dead as a dodo when attempting to head to sainsbury's for BBQ goodies. Lesson well and truly learnt |
I dint think that light should be on with the ignition off. It sound like it may not be going in and out of sleep mode properly. When you unlock the car it goes into 'wake up' starting up a load of systems in readiness of you starting the car. It stays that way for a pre determined time or until you start it.
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
no consolation but the grand cherokee does the same - radio on for less than 1 hour and battery is flat |
spoke to landrover dealer today, they said very common, they dont expect the battery to last more than 45 minutes, whilst keys are in it. they said dont leave keys and radio on. They also said its unlikely to be interference from networks as this was fixed on post 2005 cars, ie facelift models with touch screen as is the final stage resistor.
forgot to add, the dealer also asked if we have tv on the move which we havent. they have has poeple complaining subsequent;y found they have had ice shops fit a modified loom to get tv on the move and then subsequently suffer battery drainage
so far so good, have found the touchscreen takes approx 7 -10 minutes to go off when locking the car, the dealer said it should take 2 minutes ish. It seemed a bit casual but is 7 minutes normal..? |
