![]() | Home > Technical (L322) > Air suspension fault AMK compressor |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 441 ![]() ![]() |
I've bought the replacement kit https://www.ebay.co.uk/itm/114313842208 from airsealsuk, did the replacements, but still same issue...
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
I have exactly the same problem. Replaced the compressor (twice) and also the rear valve block.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
Also check the airline feed from the compressor to the reservoir, they can chaff and rub through causing a leak, will give the symptoms you describe |
Thanks Dave and Alan, I just installed the new Airsus compressor, and now it rises again. But still slowly (got the warning message "rasining slowly" ). It could be that the air pipe joint from the air suspension valve control unit to the compressor is leaking, will try with soapy spray tomorrow.
There could still be a leak if its raising slowly, but let it settle now and get the reservoir fully charged, once it has you should not get the warning if raising form say access to normal height or normal to off road, if it continues you will need lots of soapy spray and keen hearing to locate a leak. Best of luck. |
