Home > Technical (L322) > l322 Transmission range sensor |
paddylimbo Member Since: 08 Apr 2021 Location: SHeffield Posts: 6 |
HI
23rd Sep 2021 8:05am |
thanks for the reply, I was hoping it wouldn't be the switch but if I were a betting man that's what it will be.
24th Sep 2021 2:57pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
Found this video, the other one I mentioned I can't bloody find !!!! But the unit is basically the same, worth a look at.
24th Sep 2021 3:49pm |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
Check your battery if not done so already!
24th Sep 2021 6:15pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
You could test at the connector to check that the L1, L2 & L4 pins all show continuity with the +ve pin, but not L3, with the selector in the Park position.
24th Sep 2021 7:01pm |
