Home > Technical (L405) > Front Hydro Bush
fenair
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
Front Hydro Bush
Guys just had a 60 month service and the dealer has picked up on the "front Hydro Bushes " split, i do a google search on that description name on the inspection sheet but nothing comes back, any ideas as to the terminology ? is it the bush on the ACE arm?
2015 4.4SDV8 L405
TIA
Pat
Post #607080 22nd Sep 2021 6:30pm
knwatkins
Hi Pat, he's referring to one of the bushes on one of your front lower suspension arms.
A hydrobush is oil-filled as opposed to a traditional, solid rubber bush. This provides a more progressive response of the bush as the wheel deflects (ie. more deflection = more firmness in the bush).
ACE (active cornering enhancement) refers to the old active (hydraulic) anti-roll bar sytem from the Discovery 2. It's called Dynamic Response now, but many people still call it ACE. You will have this as you have the SDV8, the SDV6 does not. There are two bushes on the active anti-roll bar but these are solid rubber D-bushes which is the same as a normal, solid anti-roll bar.
Hope this helps. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #607089 22nd Sep 2021 9:04pm
fenair
Many thanks Kev That points me in the right direction, cheers.
Post #607099 23rd Sep 2021 6:28am
