![]() | Home > Technical (L405) > front diff oildrain |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
I am not lucky enough to own a L405, so can’t verify, but the workshop manual ( which is available as a free download from the wiki ) clearly shows separate drain and fill plugs.
Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
fenair Member Since: 01 Sep 2021 Location: Norfolk Posts: 47 ![]() ![]() ![]() |
BB many thanks, it must be in there deep as i couldn't visually detect anything so likely full of debris, now you have been kind enough to point me in the correct direction i can conclude the transmission service, the gearbox fluid is a messy job, the D3 was a good set up with the oil cooler pipes easily accessible to do a mega flush in one go, 3 liters at a time then a run is not the greatest idea, but better than a £4k gearbox and a lot of sweat and tears.. thanks for the info, much appreciated. Pat |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
You need to remove the brace first.
Yep its obvious when you look at it.. all done , both diffs and 6 liters of auto box fluid and new filter pan many thanks for the information 😊
Definitely worth doing |
Yep done... It's off to duckworth Boston to have a 60 month service , can do it myself but best just to keep the service records upto date. |
kungfupanda Member Since: 24 Jun 2013 Location: Manchester Posts: 226 ![]() ![]() ![]() |
Not sure why it’s different on my 3.0 TDV6? Seems more straight forward on mine.
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 234 ![]() ![]() |
For some reason the brace is not fitted to the V6 although the mounting points are there. |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
Related but kind of hijacking the tread. Did I dream there was a forum member who drove all around the country to complete this work on people’s drives. Need to get all my fluids done as just passed 80k and deciding how best to arrange as useless with spanners. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
You're probably thinking of Bodsy - 07770638023 Kev
