Home > Technical (L322) > cd changer pin outs
daveo
cd changer pin outs
i have a 2005 cd changer and i hope it will play mp3's ..i would like to power it up and try it with a mp3 disc, rather then take out the old one and fit it to find it does not... V8 facelift Range Rover Autobiography 22" wheels.
Post #60677 16th Apr 2011 11:13pm
mzplcg
I would think you might struggle to do this. Even if you power up the unit successfully you will still need the control signals which tell it which CD to load etc.
Post #60686 17th Apr 2011 7:41am
you might have a problem there dave as the touch screen selects the track you want to listen to , as dom says you'll need to get an interface to control the changer..
btw the 6 cd changer does play mp3 tracks.. ... - .- -.
Post #60689 17th Apr 2011 8:25am
daveo
when you load a cartridge it will go through the six disc to identify them if it cant read the disc it will spin like mad
then move to the next disc , so hopefully if it is mps compatible it should see the disc. V8 facelift Range Rover Autobiography 22" wheels.
Post #60703 17th Apr 2011 10:42am
