![]() | Home > In Car Electronics (L322) > Several issues with 2011 L322 Infotainment - Help appreciate |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 299 ![]() ![]() ![]() |
Behind picture number 5 is the DAB Module I had the same fault so I have upgraded it for a newer one but now that it self has problems. But the DABworks and I can listen to talk sport |
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 207 ![]() ![]() ![]() |
Re the bluetooth not working........ it's the unit in the above picture. In common with other 'MOST' connected components failure will stop the other systems working. If I were you the first thing I would try is removing the plug (that you can just see at the bottom edge with the two red sleeves) and either fit a proper bypass to it or make one. I wonder if the bluetooth module is in the throes of failure & causing intermittent issues elsewhere? No 1 does sound like amp failure but as the bt isnt working you may as well start with isolating that. Bypass loop: https://www.ebay.co.uk/itm/153071378602 Homemade bypasses: These are both slightly earlier vehicles so the module is different but what you'll do with the cable is the same. Be careful not to bend the cable round a tight bend. 2010 Range Rover Autobiography TDV8 Santorini Black 2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone] 2003 Range Rover HSE Oslo Blue [Gone] 1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone] 1990 Camel Trophy 127 (Workshop Vehicle) [Gone] 1989 Camel Trophy 110 (Workshop Vehicle) [Gone] 1998 Camel Trophy Freelander (South African Team Vehicle) 1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone] |
Deepesh Member Since: 04 Sep 2021 Location: London Posts: 10 ![]() ![]() ![]() |
Thanks for the tip! I think I will replace it and see if that has any effect. I also got the Gap IID tool today so that's throwing up a whole mess of errors ![]() |
Many thanks for that. I'll give that a try this weekend and see how I get along. I tried removing the BT module but can't for the life of me fire out how the heck it comes out. |
nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 104 ![]() ![]() ![]() |
Fibre optics seems to be the culprit a lot of the time. What doesn't kill you is just bidding it's time. |
bigben Member Since: 12 Nov 2021 Location: Northampton Posts: 17 ![]() ![]() ![]() |
Hello,
That looks like it goes to the bluetooth module |
It’s not for the bluetooth module, that’s a thin 2-core cable, IIRC black & green. Plus the MOST cable of course. 2010 Range Rover Autobiography TDV8 Santorini Black
I don't think it is a MOST cable, on my car it goes to the third input on the black antenna amplifier (assuming it is the same cable). I notice this connection does not have a cable fitted on the OP's car so was wondering if I had made a mistake in where I had fitted it, it was hanging loose when I got my car.
It's very definitely not a MOST cable. I found a picture from my 2010 AB;
So it should be plugged into the antenna amplifier. As the other end seems to be into a small loom heading upwards I wonder if its for the roof mounted antenna? 2010 Range Rover Autobiography TDV8 Santorini Black 2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone] 2003 Range Rover HSE Oslo Blue [Gone] 1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone] 1990 Camel Trophy 127 (Workshop Vehicle) [Gone] 1989 Camel Trophy 110 (Workshop Vehicle) [Gone] 1998 Camel Trophy Freelander (South African Team Vehicle) 1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone] |
sorry misread your post.
Shinner23 Member Since: 18 May 2020 Location: Virginia Posts: 6 ![]() ![]() ![]() |
What are the green/black(or grey?) wires that go into the bluetooth module? My BT always sounded like I was talking to someone in a wind tunnel, then all of a sudden, it just stopped showing up in my bluetooth settings on my phone. I pulled out the MOST wires, and the one still has a red light on the end. The Phone screen gives me the "If you have a phone you can connect." , but nothing shows up on my phone. |
That’s the power to the module.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
this from our wiki is interesting reading re the MOST system,
