![]() | Home > In Car Electronics (L322) > 06 L322 - How to stream from iphone? |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3156 ![]() ![]() ![]() |
I use a male to male 3.5mm audio cable connected to the rear aux in socket that hides under the flap on the rear of the cubby box.
Grayson Welly Member Since: 05 Sep 2021 Location: SW20 Posts: 95 ![]() ![]() |
This is an incredibly helpful and well explained response. Thank you for this and the links.
That's quite interesting, I hadn't seen that before. I don't like that big charging socket sticking out of the rear socket though. If I was fitting that I'd try and get power to that device without having it visible like that as I like subtle.
The video is a little amateurish and doesn't give an image of the final product, unfortunately.
This is a great tip for streaming bluetooth.
Archieatkins Member Since: 15 Oct 2019 Location: Birmingham Posts: 129 ![]() ![]() |
I got really excited by this when I saw the thumbnail and then I watched the video and nope - looks far too messy for me. |
Which one Archie? --------
The luxury Land Rover one. I have the Bluetooth dongle into aux solution at the moment but thought this might be some sort of replacement port unit from the picture |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 ![]() ![]() ![]() |
I use an Amazon Echo Auto plugged into the Aux port in the rear. Very pleased with it. |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 ![]() ![]() ![]() |
Can you play music from your phone on the echo? 2009 (2010 MY) 5.0 Supercharged Autobiography
Yes.
Brilliant, I did not even consider this, I’ve got a little Bluetooth dongle, but I want something better, does it connect as soon as you get in or do you have to manually connect every time? 2009 (2010 MY) 5.0 Supercharged Autobiography
Yes, pairs automatically.
Absolutely, thanks for the suggestion, I’ll try it out I think 2009 (2010 MY) 5.0 Supercharged Autobiography
