![]() | Home > Maintenance & Mods (L322) > Rear caliper question please |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 504 ![]() ![]() ![]() |
Yes they use a banjo bolt (where it connects to the rear brake caliper).
Dode4444 Member Since: 18 Jan 2021 Location: Buckie Posts: 43 ![]() ![]() ![]() |
Thanks very much!
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1223 ![]() ![]() ![]() |
Copper washer size on a 2006, ( most likely the same banjo bolts ) - ID = 10mm, OD = 16mm, thickness = from 1mm to 2mm, if using old washers or new 'old' stock always remember to anneal them first to get a good seal. |
Thank you.
I bought mine from Duckworths (site sponsor) and they came with new bolts and copper washers |
Have already bought my calipers unfortunately they are already on the way. 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black |
Noooo, the brake pipes came with the banjo bolts and washers fitted.
Sorry my mistake haha.
