Home > Technical (L322) > supercharger on a 4.4
pretlove
found this thought it was intresting....mind you if you want a supercharged range it would be easier to just buy one...
http://www.koperformance.com/BMW/turbo_sup...38_740.htm "RANGEISM WILL NOT BE TOLERATED"
Post #60596 16th Apr 2011 11:52am
BigJ
United Kingdom 2005 Range Rover Vogue 4.4 V8 Stornoway Grey
Yup seen it, VF is spot on.
The Rangie is no quick car tho.... Problem with the new supercharged engine is it's the Jag/Ford lump. I've owned it before and lovely motor, but problems are rife on them.
I did think about this, but then is putting the 4.8 Litre BMW engine in easier? Not as much power tho... Used to have:
2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped
Now have:
2008 SSRR 3.6 TDV8 - HSE and plenty of toys
Post #60614 16th Apr 2011 1:29pm
pretlove
i think there would be issues with the gearbox if you put the 4.8 nengine in and ass you say less power "RANGEISM WILL NOT BE TOLERATED"
Post #60624 16th Apr 2011 2:10pm
3R10
France
From what I've read, the best way to increase power would be boring and stroking the BMW engine to 5.2L. That would give approximately 400-420BHP depending if you change the exhausts too. Then, maybe a supercharger on top!
I've seen somewhere a 600+ HP 740iL, so the results would be the same on the RR. (although, this would be cost prohibitive I guess...) 2000 BMW M5, Avus Blue/LeMans Leather Interior
2006 Range Rover Westminster Java Black
Post #60663 16th Apr 2011 8:41pm
