![]() | Home > Technical (L405) > 2013 RR L405 Autobiography with Odd Issues |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Might be worth disconnecting the battery positive and negative leads for 10 minutes (minimum) then touching the positive and negative leads together for 30 seconds and reconnect them to the battery. This will carry out a reset of the ECU's and might resolve the issue for you. 2011 TDV8 Vogue SE |
KarlC Member Since: 23 Feb 2017 Location: San Diego Posts: 11 ![]() ![]() ![]() |
That's a thought, could the reset casue any issues ?
You'll lose the time/date and any other personal settings you may have such as one touch windows and radios stations etc. Do you have a secondary battery in the boot/trunk? 2011 TDV8 Vogue SE |
We don't really have any personal items set up so no worries there.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Check the voltage when the engine is running, should be around 14.5volts, Then check the battery voltage about 30 mins after switching off, then test again a day later and see how much the voltage has dropped, it could be a parasitic drain causing your problems. Pete
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 239 ![]() ![]() ![]() |
The 2013 doesn’t have a secondary battery as there is start-stop. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
to check to see if you do have an aux battery, look inside the rear right panel [as you stand at the back looking towards the front] ... - .- -.
As an update, I called IE Rovers .... https://www.facebook.com/IERovers/ ..... https://www.yelp.com/biz/ie-rovers-lake-elsinore ... late yesterday, they said bring it in 1st thing in the AM and we will have a look for you.
When I took it to the INDY IE Rovers , they ran a diagnostic. |
Thx all for your input.
That’s utter BS I’m afraid sir… Only MD can look at your can system 🙄
What he said..... |
I assume the battery wiring is nice and snug? (Tight for us brits 😏) |
Thank you for the input guys. Thanks for your help ![]() . Last edited by KarlC on 7th May 2023 4:24pm. Edited 3 times in total |
