Home > Maintenance & Mods (L322) > Amk retrofit help |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
That temperature was filling an empty reservoir it’s now peaking at around 70c not sure if that’s normal or not? Also the behaviour had sorted itself out - I had noticed that the blue and white wires coming off the pump were reversed on the other side of the connected so I swapped them it didn’t make much difference what is this for and do I need to swap back? Current stable:
6th Sep 2021 2:10pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1189 |
What I did and what is recommended is to replace the relay as well when changing the compressor don`t know if that will solve any problems as it`s only a switch?
6th Sep 2021 5:27pm |
Thanks…
6th Sep 2021 8:10pm |
When things happen that you can`t explain it will do your head in but then that's what owning a ffrr is all about |
6th Sep 2021 8:58pm |
