Home > Technical (L322) > Rumble/vibration at higher speeds - SORTED (pg2 post 7)
Samuel
United Kingdom 2004 Range Rover Vogue SE 4.4 V8 Buckingham Blue
You may want to check the condition of Motor mounts.
Post #560164 4th Jul 2020 8:23am
coopss
Just stopped after 90 minute drive - the rear right tyre (OSR) is warm to touch, the rest are cool. Brakes all feel the same temperature
On the way back from Gotts last night I did 4 sets of heavy braking 70-30 ish and the first 20 miles of the drive were smooth. Now it’s back to the way it was, with the OSR tyre being warm to touch 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #560175 4th Jul 2020 9:16am
DrRob
Sticky caliper maybe?? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560185 4th Jul 2020 10:34am
coopss
Certainly seems to point towards something in that area. Nothing warm other than the tyre. Odd 1995 4.6 v8, green/tan (long gone)
Post #560188 4th Jul 2020 10:52am
Nick591
Put the spare on in place of the rear right? See if it makes any difference?
Might it be worn rear bushes or tracking/camber settings causing the rear right to not run true in line under load. When you braked hard it might have pushed things back into position for a few miles? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #560241 4th Jul 2020 7:29pm
coopss
As it’s getting a little more noticeable, It’s looking like 2 issues:
1. Rear right brake binding. Slightly warmer than the rest after a drive and the pads are more worn.
2. Front right bearing. When driving and moving the wheel very slightly left to right I can feel the vibration come and go as the weight shifts (doesn’t change when braking aside from a very slight noise with forces shifting)
I’ll jack up each corner and see what I find. Had a look underneath yesterday and found the front diff covered in oil - something above it is leaking but can’t see what. And a gaiter has been pinched as some point - very thin line of grease decorated underneath 1995 4.6 v8, green/tan (long gone)
Post #562103 20th Jul 2020 11:13am
coopss
SORTED!! Well chuffed. 2 bent wheels...
There is a slight resonating vibration/rumble sound which is slightly worse on acceleration. All in all it’s fine as the bad part is sorted - the ride has vastly improved as well.
A very good point made by someone on another post is that the CVD system reacts to wheel hop and tries to reduce it by hardening that damper. The bent wheel was causing the CVD system to harden up so I had 1) vibrating car through the seat and 2) a terrible ride. What threw me off is that occasionally it would be fine, this was presumably due to the CVD not adjusting to the bent wheel and hiding the problem.
Just the heater, heated seats, tailgate straps, rear washer, windscreen moisture issue, a bit of paint and new rubber mats to sort now!! But at least it’s a joy to drive (albeit freezing with no heating)
Thanks for all the help
Edit: this has been to 2 specialists and another garage who could not find it. The place who put the new tyres on didn’t tell me this until they had it back for the third time 1995 4.6 v8, green/tan (long gone)
Post #577706 29th Dec 2020 8:15pm
DrRob
Great news Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #577711 29th Dec 2020 9:04pm
jackie-o
Netherlands
How did you figure out it was bent wheels?
I have the same in my (wifes) car. Drives fine until about 60 mph and then starts vibrating. At around 75 mph it vibrates so much that you can see the passenger seat shaking (our car is LHD).
I had all wheels rebalanced and tyres are only a year old....
I could try to swap for another set of wheels to see if the problem goes away, in the meanwhile any other suggestions?
//jonas RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #605730 6th Sep 2021 1:51pm
coopss
Had them rebalanced twice and new tyres fitted - no difference. The third time they re-balanced them I was told 2 were bent. Swapped the wheels and it was sorted 1995 4.6 v8, green/tan (long gone)
Post #605749 6th Sep 2021 4:41pm
jackie-o
Netherlands
So, my tyre shop had just installed a new Hunter Road Force machine which apparently measures everything.
Turns out all wheels were fine but one tire was damaged internally, likely from hitting a pothole or curb, and beyond repair.
So two new tyres need.....annoying as only a year old...I wonder if the Pirelli tyres with the noice canceling foam are more sensitive to damage?
Really cool machine btw which tells the shop how to adjust the tyre on the wheel to get the balance exactly perfect. Then also which wheel goes on what corner of the car.
Could be worth a shot for those experiencing rough rides to see if there is any improvements.... RR Vogue 4.4 TDV8 - 11
Post #606963 21st Sep 2021 8:23am
