![]() | Home > Maintenance & Mods (L322) > Idler pulley replacement 2012 4.4 TDV8 - how to |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
This how to is how I managed to change all idlers, as I was doing this alone I did it without removing the lights, bumper, crash bar & full rad pack & risking damaging it.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
Great write up thank you for spending the time to do it |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Excellent write up! I’ll be tackling this over the next week so extremely helpful! Thank you! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Smitch Member Since: 05 Oct 2021 Location: North west Posts: 40 ![]() ![]() ![]() |
I’m doing this job now, got everything out and have replaced the tensioner and idlers around it, now I need to do the other side. The aluminium pipe that’s obstructing the last two has been unbolted but not disconnected in any way, do I just disconnect the top and move it out the way or does it need to come out?
Do you mean the pipe to the left of the engine as you face the car?
Yes, it’s to the left and runs diagonally across one of the pulleys and the alternator.
As I’m so close to it I’m seriously considering swapping the alternator out as well as I’ve seen loads on the Facebook group fail on this age and mileage car. :/ |
Yep that’s the one. You unscrew it, pop the top two clips and it pulls away.
Awesome thanks for the heads up I’ll see if I can get that done tomorrow then (doing little bits at a time due to time restrictions)
I used one of these for the belt. A little fiddly… but worked well
Mine is similar- Lisle Tool's 59370 Stretch Belt... https://www.amazon.co.uk/dp/B00AC60VEC?ref=ppx_pop_mob_ap_share
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1293 ![]() ![]() ![]() |
Nice info for the belt stretcher. My last pulley is arriving tomorrow. Just got to get some coolant and I'm ready to get on with it. |
