![]() | Home > Maintenance & Mods (L322) > L322 4.4 tdV8 (2012) Battery Drain |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
It will drop due to various systems booting/initialising then should recover. Your focus from my experience should be the charging system which should be @14.5~7. Clean and tighten the terminals (make sure there is very little resistance) reset battery. If this improves the charging then alternator is good, if it is flakey then you have bad contacts in the circuit.
longd Member Since: 24 Oct 2020 Location: West Midlands Posts: 95 ![]() ![]() ![]() |
Hey dude , your 100% I pulled off the heavy duty positive lead that runs to starter and alternator and it was giving 1v or less with engine running ,
have you checked if that cable has a short to ground? After the reinstall pls reset battery and check. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
Cable is sound , no continuity to ground |
I learnt the hard way |
Here’s dude , I’ve dropped alternator off to specialist to check , hopefully he will say it’s duff , and it will be the end of my problem , otherwise it’s back to the drawing board ! |
