Home > Technical (L322) > 2012 towing electrics
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Hello, my 2012 Westminster came with a black and a grey socket electric system. Due to covid we haven’t used the caravan at all so far but might use it next month.
I prefer the 13 pin system (which my caravan has) so I ordered a 13 pin kit from p f jones. I hoped to just swap it over but I have read conflicting information on this. Does anyone know if the vehicle would have to be re programmed for the 13 pin version ?
I have searched on here but just getting more confused ! Thanks
Post #605358 1st Sep 2021 7:38pm
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
I had the single black and swapped it with
The 13 pin I did tell the car via my iid tool but I think there plug and play anyway, fit it and try if it needs enabling ask on here if anyone local can do it for you 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #605360 1st Sep 2021 8:14pm
4040
Thank you. That’s also why I’m confused. It says plug and play, then it also says there is coding ‘yes’ then all sorts of other conflicting information about reverse sensors and fog lights !
I guess if I just fit it soon and try it I will have time to get any coding sorted if necessary.
Post #605362 1st Sep 2021 8:28pm
Furnitureman
I may be wrong but as yours has the twin electrics the 13 plug should be the same set up just one plug so if the reverse sensors etc work now they should be ok after 2012 Range Rover Westminster 4.4 TDV8
Post #605365 1st Sep 2021 8:48pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I swapped over from a two plug to one plug 13 pins? on my 2011 SE? When the car has never had a towing system fitted then it needs to be programmed as was the case for my 2012 AB.
Post #605366 1st Sep 2021 8:53pm
