Home > Maintenance & Mods (L322) > L322 3.6TDV8 Ride Quality / BWI Front Struts
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I've been contemplating changing front struts for a while due to poor ride quality of what I think are the original air bags / dampers (2006 3.6 TDV8). Having driven my brothers 4.4 TDV8 yesterday, I've decided mine is not good at all.
Knowing the significant difference in ride quality between different damper manufacturers, I'm not willing to spend the £500+ without some confidence that the ride will be better.
Has anyone in the West Midlands changed their front struts to BWI (Delphi) in the last 12 months or so & would be willing to let me sit in for a brief ride to confirm ride quality ?
I'd possibly have more confidence in genuine LR supplied parts (even if they're made by the same suppliers) - but the £600 + premium is a bit excessive Shocked Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #605212 30th Aug 2021 6:29pm
Your brothers 4.4 will have adaptive suspension which, when working correctly, will be significantly nicer than the earlier setup...
I think Delphi are OE for struts, I know that the Dunlop ones weren't considered well made..!!
When I changed mine on my 2002 the rears made a massive difference to ride and comfort, not so much the fronts......!! Pete
Post #605247 31st Aug 2021 10:40am
Pawl
Pete,
thanks for the response.
Yes, the brother's car has got adaptive dynamics.
I'm assuming it is working well, the ride appeared a lot softer than our 3.6, but well damped after some initial travel.
I imagine it stiffens up when cornering etc.
It inspires a lot more confidence in the way it deals with bumps & undulations than ours,
Your comment about changing the dampers on yours is interesting.
I changed the rear dampers on ours due to "excessive misting" maybe 2 years ago - to the Bilstein option Island4x4 had got.
I didn't think the ride changed much at all compared to previously, still relatively firm.
Your comment about the front's is what concerns me ref changing mine & makes me want to try someone's who's changed to the BWI units.
The current ride isn't anywhere near what I would consider good or "limousine" like.
I'd say the front spring rate appears too high & the initial damping as you hit a bump too stiff - neither of which are what I'd normally expect from old / worn units - despite their age.
When I bought the car it was the same & I'd factored in replacing the struts as I initially thought they might even be siezing up due to being unused for a while.
After changing the suspension height between Off-road & Access height a few times I discarded the idea of them being siezed as it changed height quickly & smoothly.
From what I've seen elsewhere BWI have bought & owned the old Delphi suspension division since 2009.
People who've fitted their aftermarket units to Discovery 3s & 4s seem to think the ride is OK & back to original.
On various non Land Rover forums, various owners believe the damper designs have been changed & cheapened - often saying the ride is worse than original. Paul,
Post #605250 31st Aug 2021 11:49am
Lots of other suspension and steering components that can wreck ride and handling...
Worth getting the whole lot checked before guessing... Thumbs Up Pete
Post #605316 1st Sep 2021 12:23pm
Pawl
Pete,
I've been over the rest - all in good condition.
It's definitely an air bag / damper "issue" Paul,
Post #605319 1st Sep 2021 1:06pm
Maybe it is insufficient damping that is causing the suspension to "slap" over irregularities, which could feel like it's too stiff....
Airbag pressure is linked to height so if height is OK then the pressure will be correct, or maybe a tad more with failing shocks....!!
If everything else is Ok then it's only them left unless anyone else has some thoughts..... Pete
Post #605338 1st Sep 2021 4:15pm
Pawl
Pete,
I'm wondering if the stiff ride could be down to air bags getting stiff with age.
I've got no comparison, but I was expecting to be able to push my fingers into the bags locally as an indication of flexibility of the rubber.
On ours you can't do that at all. Paul,
Post #605341 1st Sep 2021 5:00pm
They are very thin rubber, thinner than a bicycle tyre but the pressure they run means they have no give in them that your hand will feel, don't think they would ever get hard enough to compromise ride quality...
They are fabric reinforced rubber to stand the pressure.... Thumbs Up Pete
Post #605348 1st Sep 2021 5:46pm
Danwilderspin
I’ve got some bwi I’m about to fit on my 2007 s/c my problem though differs you yours I think as my ride is too bouncy Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #605371 1st Sep 2021 9:54pm
