Home > Technical (L322) > Fluid on passenger side
SinbadRose
Found fluid on the floor on the passenger side, right under the door. Checked fluids and think it's break fluid as it seems the reservoir is now in the middle not near the top. Do the lines run on the outside to the rear, if it is that, how long to fix (garage doing it) or if I can find the hole is there a fix I can do to cover it for a couple of weeks while we are away?
Thanks in advance all
Post #605183 30th Aug 2021 2:51pm
Baltic Blue
You will have to get under and remove the plastic covers to fully inspect the brake pipes, which are very prone to corrosion.
Get someone to press the pedal whilst you look for leaks, but wear goggles just in case it bursts.
Post #605186 30th Aug 2021 3:44pm
SinbadRose
Thanks for that baltic. I will see if i can get it in a garage this week to get it sorted. Back in work first thing and wont have time to get it sorted by friday
Post #605199 30th Aug 2021 5:48pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
This what you should see. inline unions for both rear lines:-
Post #605205 30th Aug 2021 6:55pm
