Home > Technical (L322) > Problem "Engine failure system" |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Try unplugging the EGR electrical connectors. My brother's 08 RRS TDV8 has an EGR valve that must be incorrectly reporting the EGR valve position because since unplugging the electrical connector the engine no longer has its restricted performance issue. |
29th Aug 2021 7:39am |
Zerocult Member Since: 29 Aug 2021 Location: Jaén Posts: 7 |
Thanks friend for the advice. I'm going to test your solution these days. I cross my fingers that in the end it is that. I will keep you informed of the situation ... |
29th Aug 2021 9:53am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
As there are some differences between the Sport and the FF 3.6 engine, it would be worth posting on the sister forum https://www.rrsport.co.uk/forum/ as well. John
29th Aug 2021 10:22am |
Today I have tried the solution that the colleague commented. But unfortunately it continues to do the same. |
30th Aug 2021 9:38am |
From the WSM...
30th Aug 2021 11:46am |
