Home > Maintenance & Mods (L322) > 3.6 TDV8 Alternator failing ??
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Any experience of partly failed alternator symptoms ?
Our 2006 3.6 TDV8 has been failing to start until "boosted" with increasing frequency.
Once the battery booster (NOCO unit) is attached for a few seconds, it starts instantly every time.
The battery is a Varta 020 that's approaching 3.5 yrs old & definitely weakening as it's only showing 12V occasionally prior to start-up & at its best maybe 12.5V - despite regular external charging via a CTek when the car isn't used for a few days.
Investigating what's going on has identified I've got a battery drain of approx 1 amp after system shutdown that isn't Entertainment / SatNav system related. I think 0.3A of this maybe the infamous Final Stage Resistor in the HVAC system & further investigation is underway to understand what else can be causing the remainder.
The alternator is draining some current, but it appears to be less than 0.02A - so not significant.
However, I've now noticed that sometimes after engine start-up, the system voltage is only climbing to 12.9~13.1V - even revving the engine.
Other times, the voltage immediately climbs to 12.9 or so & continues to climb over the next few seconds to 14.2V - which is more what I would expect from an OK alternator output.
PS there's no obvious whining noise from the alternator.
I know the battery is in need of replacement, but is the above another symptom of an alternator failing as well ?
My past experience of alternator failure has always been of instant total failure - with no intermittent variations.
Any thoughts ? Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #604744 25th Aug 2021 12:57pm
ur20v
A Trap
Deleted
Post #604754 25th Aug 2021 3:58pm
There's a few threads on TDV8 alternators. The 2007 vintage seems particularly fragile.
Some go with what appears to be no warning, but there's usually been a few clues leading up to it. Could be either - the problem is as above - I did exactly that, put a new battery in & a few weeks later it failed completely and killed the battery in the process. So my tip is buy one with a good warranty & keep the receipt - Euro Car Parts were very good, no quibble exchange Thumbs Up
Post #604758 25th Aug 2021 4:16pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
My alternator was failing for a couple of weeks - I suspected the battery at first but had a rude awakening on a dark Winter’s evening when I didn’t make it home due to complete failure of the alternator.
I monitored the voltage via the hidden menu for a few days and it fluctuated then made it to about 13 volts after a few miles.
By the time mine was going (on the day it expired) it was giving out about 11volts, leading to me not being able to engage Drive without using the manual release under the centre console when I tried and failed to make it home from work.
If you are going to bite the bullet and fit a new one yourself, do it soon while the weather is good. I did mine over 2 days just after Christmas, with near freezing temperatures.
Also, go for Denso, don’t be tempted by the cheaper one at Euro Car Parts. I did at first and noticed a difference in the position of the main terminal connector, adding a few more days to the job. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #604761 25th Aug 2021 4:42pm
Jase0851
2012 Range Rover Vogue TDV8 Orkney Grey
my alterntor was fine until one day on a trip to york all the dash lights came one then total darkness and rolled to a stop. No other warnings at all, bit of an awkward job on the 3.6 aswell and cost me about 600 in the end iirc
Post #604767 25th Aug 2021 5:59pm
Pawl
Thanks guys - useful additional info !
Since the earlier post, the car has already failed to start once after a short journey with the alternator only producing 12.9V , but then charged fine at 14.2V on the following journey after being boosted.
It's definitely getting worse Mad
Based on what you've said, I think I'm going to "bite the bullett" and replace the alternator as well as the battery.
Based on past experience & the suggestions I will go for the Denso unit. The existing part has lasted 16 years & my experience of other makes has not been positive.
I had to change the PAS pump & steering rack on the house driveway 18 months ago, so I'm probably equipped for the pain I've seen involved in changing the alternator Very Happy
I'll report back when done !
Thanks again,
Paul Paul,
Post #604803 25th Aug 2021 8:42pm
chris_read
Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #604825 26th Aug 2021 7:43am
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
A failing battery or poor terminal contacts will do it as I found. Suggest clean tighten the distribution also (behind the battery)
and then you have to tell the car you have a new battery
Good Luck SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #604901 26th Aug 2021 11:08pm
Landmark
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Battery alternator
Has the car been programmed to accept new battery. There is a list on iid tool to select. I think this helps the alternator coordinate charge cycle times etc.
Post #605311 1st Sep 2021 11:13am
Pawl
Landmark,
it's not needed on the earlier pre-AGM battery cars.
I've now changed the battery as it was failing to start so often despite being charged externally every night.
Prior to start up it was often only showing 11v
Interestingly, the charge voltage on start-up is now 14.2V everytime. No intermittent 13V charging.
It appears to suggest even the alternator needs more than 12V fed from the battery to make it work corectly & consistently ??
I haven't checked the battery drain values post shutdown yet to see if they'eve improved with more than 12V always available. Paul,
Post #605313 1st Sep 2021 11:33am
