Home > Maintenance & Mods (L322) > SGS Engineering trolley jack,
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
I need a trolley jack and after a bit of searching found the following.
SGS 3 ton low profile trolley jack. Model TJ3LP-JSR.
The lifting range is from 98mm to 535mm which does sound like it might lift high enough.
Has anyone on here bought one and is 535mm high enough to lift a L322?
Its £166.79 which includes 2 heavy duty ratchet axle stands.
Any feedback or recommendations most welcome on the jack and SGS Engineering.
Many thanks. 2009 Vogue SE Zermatt silver
Post #604747 25th Aug 2021 2:19pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Have a look here…
https://www.fullfatrr.com/forum/topic59739.html
I ended up ordering the “SGS 3 Ton Heavy Duty Trolley Jack With 4 Ton Ratchet Axle Stands - TJ3X-JSR” which is a great jack and axle stand set… but I’ve needed to use blocks of wood to get enough height for the L322. That jack has a max height of 465mm and the one you suggest “only” has an additional 50mm.
I’d have to check to be sure, but I would expect that to still be a bit tight without an extra boost with blocks… albeit less of a boost than what I need.
I intend to buy another jack more suitable to raise the L322, and relegate the other jack to other lifting duties so I am interested in what you get and how you find it. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #604752 25th Aug 2021 3:44pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Better of getting a bottle jack for the range rover. Can get some decent ones for less then 100quid
Post #604762 25th Aug 2021 4:50pm
mrtidy
I must admit I thought the sgs jack would have enough lift,not so sure now so might have to seek out a decent bottle jack. 2009 Vogue SE Zermatt silver
Post #604778 25th Aug 2021 6:34pm
kbald
I've got the tj3 sgs Jack which is fine without blocks. The tj3x is low profile so doesn't lift as high. Current 2007 TDV8 Vogue Buckingham Blue
Post #604793 25th Aug 2021 7:55pm
kbald
I have had mine a few years now and think it did go higher than the ones they are quoting on the sgs website. 583mm seems to ring a bell thinking back Current 2007 TDV8 Vogue Buckingham Blue
Post #604795 25th Aug 2021 7:59pm
Ffrr-lover
Ah that explains it! I got the jack on recommendation… and clearly I got the incorrect one! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #604796 25th Aug 2021 8:05pm
mrtidy
Looking at sgs website the TJ3LP jack goes from 38mm to 535mm lift height, thats about the highest I can find on sgs, I'm thinking that would probably lift my fatty and the wife's mini and my sons jag xe, just still not sure if that's high enough. The product code numbers all seem very similar. 2009 Vogue SE Zermatt silver
Post #604802 25th Aug 2021 8:40pm
kbald
Just been to the garage to check mine and it goes to 520 so the LP one if that goes to 535 should be spot on. Mines lifted the car many times and is high enough for the suspension full travel without maxing out Current 2007 TDV8 Vogue Buckingham Blue
Post #604851 26th Aug 2021 4:38pm
mrtidy
That's great thanks for checking that, think I'll order one today 2009 Vogue SE Zermatt silver
Post #604866 26th Aug 2021 6:51pm
