![]() | Home > Maintenance & Mods (L322) > 2010 L322 Electric Rear Seats Not Working |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
Hi Richard, I don’t have the electric seats but have a similar problem which may be the same issue you are having with no lower going to the rear seats. My issue is the rear seat heater buttons don’t light up and the seats don’t heat, however on two occasions in the last 3 years they have all of sudden worked but went off again after about an hour. I think the rear seats are wired through the same fuse that lights up the gear selector panel ie the one that lights up red when in park and changes to orange when on other gears. When my seats worked on the 2 occasions that panel lit up whereas usually the gear selector lights never work. I’m guessing my problem is a dodgy earth somewhere and you may have the same issue.
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
Please make sure this is not turned on
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 207 ![]() ![]() ![]() |
Hi, Interesting issue......... I think though that the problem I'm having is not just a blown fuse. There are I think it's 10 fuses which provide power for the rear seats. The majority of them though provide power for other functions which work fine. I've also checked all those fuses (for continuity & resistance) and they're ok. My gear selector indicator does indeed light up. I've always tried with the engine running (the heating / chilling I think is dependent on the engine running), there are no indications that the battery is under-performing & the front seat heating / chilling works fine. Because the rear seats are controlled by the front seat modules (but the front seats work fine), one for front left & rear left seat and one for front right and rear right & I believe the wiring is routed separately I can't see a common point that could cause this. I'm wondering now if the seats have been intentionally disabled, if so though it's not just by disconnecting the plugs under the rear seats. It would be nice if when it goes into the garage (but not for another 2 1/2 weeks) that they discover the seats have been disabled by computer and can re-enable them, fingers crossed. Best regards Richard |
Hi,
Ah, alas;
Sadly it's not just the isolation switch being on ![]() Thanks though & best regards Richard |
Hi, do you have the Gap IID tool ? If so you could check they are classed as fitted in the car CCF file. That would be one way for someone to disable them. If in the file it says Not Fitted then that could be the issue. We got a 3.6 for mu son in law that had deplorable side steps fitted but didn’t work, the CCF file showed not fitted so we changed it to fitted and they worked straight away if my memory serves me correctly. |
Hi,
Hi Richard, I’m not too sure the GAP tool will be able to access your CCF file or if it does it may not allow you to change it. They are VIN locked but I can check for you possibly tomorrow, both my son in law and I have one each so I will check mine in his car to see if I can access his CFF file or someone on her may be able to confirm if it’s possible or not. If it’s possible I don’t mind you using mine to check, I’m just off the A1 about 3 miles north of the metro centre. |
Sorry just realised what you were asking , it definitely has a CCF option for rear climatic seats ! |
Hi,
Not too sure about rear electric seats, I would have to check tomorrow and let you know. When I was hunting information regarding my rear seats I noticed how the power goes through various electrical circuits, switches, relays and earthing points before it hits the rear seat heaters. I’m sure my issue is an earth point along the circuit as they did work on two occasions so definitely an electrical issue that no one else seems to have had as no one seemed to have suffered the same issue which is surprising. |
A unique problem on any Land Rover is certainly, well, unique! haha
Hi, there is indeed two options for the rear electric seats in the CCF files, rear seat recline movement and rear seat lumbar movement. Obviously they say not fitted on my car but would be interesting if it says the same for you, can’t imagine anyone would turn them off with a diagnostics tool though. Hope this helps. |
Excellent, thanks for the info.
kevinRR2010 Member Since: 24 Jul 2023 Location: Glasgow Posts: 3 ![]() ![]() ![]() |
Hi RJPotts. I have exactly the same issue as you describe in a 2010 Autobiography. Did you get an answer as to why the electric rear seats do not work, no climate control working either, yet the climate control lights up on the door.
