Home > Technical (L322) > 3.6 TDV8 Exhaust Valve - ALL Replaced. Still Fauly |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2471 |
The brass breather on the exhaust line gets blocked - drill a small hole through it. |
22nd Aug 2021 8:41pm |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 |
I've removed this. Still no luck, I've replaced everything in the rear spare wheel arch. |
22nd Aug 2021 8:42pm |
But thanks for the suggestion! |
22nd Aug 2021 8:43pm |
tezza Member Since: 22 Jul 2021 Location: Gloucestershire Posts: 78 |
Is removing it an option or does it need to see some kind of pressure restriction there. I had a similar problem recently with the 35mph suspension warning and I seem to remember it wasn't happy with the silencer completely removed.
22nd Aug 2021 9:34pm |
Is there a fault with the electrical supply between the suspension ecu and the pilot exhaust valve?
23rd Aug 2021 6:18am |
Sorry, the 3.6's suspension ecu is under the left end of the facia but has the same set of connectors. |
23rd Aug 2021 6:32am |
That's the thing. With the previous compressor/ exhaust valve I tired it installed/ removed. No difference. This one actually has a hole drilled in it, but I'm going to remove it completely and see does it make a difference with this compressor unit. On the plus side, at least it *sort of maintains height!!! Nonthing worse than bumpstops! |
23rd Aug 2021 8:44am |
I'm going to try this and see if perhaps this is causing the issue. I'm really clutching at straws now! Will report back! |
23rd Aug 2021 8:45am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Try stripping down the desiccant dryer on the suspension compressor , it may be saturated, you can reuse the beads after heating them up in the oven to regenerate for a couple of hours. |
23rd Aug 2021 10:00am |
I actually replaced this part when I swapped over the compressor unit with a spare.
24th Aug 2021 2:09pm |
Here she is.
24th Aug 2021 2:19pm |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 |
Faulty or broken level sensors can be a problem as they corrode internally if not used for a while. |
24th Aug 2021 4:51pm |
