Home > In Car Electronics (L322) > Radio interference
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Radio interference
Afternoon all
So I'm out in the 2006 4.2 and I've noticed the radio seems too throw out a bit of static noise pretty much the whole time however sometimes on the instrument cluster it will come up saying what radio station I'm listening too but for some reason randomly it will just cut out for a second or so then it comes back on with the main power on button flashing. Soon as you turn the stereo off the static goes so I'm some what lost with this.
Cheers all
Post #604273 20th Aug 2021 11:59am
CongoBoy
South Africa 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Do you have a cell phone charger plugged into the cigarette lighter socket?
Mine did exactly the same and I realised that it only happened when my iPhone was plugged into the charging cable.... 2005 FFRR SC Java Black with Overfinch Exhaust (UK)
2008 D3 HSE Stornoway Grey (UK)
2008 D3 HSE Izmir Blue (ZA/Zimbabwe)
1995 D1 300 Tdi (Zimbabwe)
Post #604274 20th Aug 2021 12:05pm
Bean19844
Only the cigarette lighter but even if that's removed the static is still there. I've noticed the radio station appears randomly on the cluster and then disappears. It's almost it like the radio is hunting for the station if that makes sense
Post #604275 20th Aug 2021 12:21pm
CongoBoy
Ok. Sorry it's not that.
When I unplugged mine, it cleared up straight away and all the radio stations came back.
Realised that it was some parasitic thing caused by the charger. 2005 FFRR SC Java Black with Overfinch Exhaust (UK)
Post #604276 20th Aug 2021 12:28pm
Bean19844
Any suggestions is always welcome mate. Might not have fixed it for me but might help someone else out who's reading this thread
Post #604277 20th Aug 2021 12:43pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Just a thought here that I kinda had the same problem with. Have you changed any lightbulbs over to LED by any chance, or some LED bulbs fitted you don't know about? The reason is because, I swapped over my rear lights from clear supercharged ones to smoked supercharged ones and the bulbs that came with it were all LED. So when I tested the lights after fitting, my radio did exactly the same as what you describe. so just swapped the bulb holders over with the old ones and radio was back to normal. Luckily the radio was on when I tested the lights so found out straight away. I presume they was cheap crappy Chinese toot and went straight in the bin. Hope this maybe some help to you.
Post #604339 21st Aug 2021 10:41am
Bean19844
Good shout that one mate. I changed the lights recently when I got the car but it kept the original bulb holder so was just the lenses that was changed from clear to smoked lights.
I've just been looking through my phone and found this screen shot from my gap unit so wonder if it's the amp that's playing up.
Post #604345 21st Aug 2021 11:16am
Barmybrummie
I have those same faults too, I clear them and they come straight back but don't have a problem with my radio. Sounds like it maybe a problem with an earth wire somewhere. Did it only start to do this when you changed the lights over? If so that would be a good starting point. A loose wire or bulb.
Post #604351 21st Aug 2021 12:22pm
rar110
It’s a bit similar to how my audio fault started. Now nothing at all.
https://www.fullfatrr.com/forum/viewtopic.php?p=603777#603777
Can’t find how to fix it. ______________________________
Post #605045 28th Aug 2021 1:34pm
Bean19844
Any of this look some what dodgy to you guys. Had a look in the wiring section and it appears too be nice and dry. I'm still getting the interference however I have noticed that now and then the radio picks up the name of the station and you get a short period of normal radio but then soon get the static sound back. I'm thinking given that speaker 11 is apparently faulty would this have a potential interference as its no longer a complete circuit?
If you look closely at the white wiring it's been connected with an electrical junction block. Pretty sure land rover never bodged jobs like this but anyone happen too know what this white wiring is for
Cheers all
Post #606376 13th Sep 2021 6:18pm
