Home > Maintenance & Mods (L322) > Suspension inactive after wheel alignment? |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 |
Steering angle sensor wants recalibrating maybe. |
19th Aug 2021 10:42pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
It should reset itself after a mile or two of driving? But to be sure, have you done a full lock to lock? |
19th Aug 2021 11:42pm |
jm1489 Member Since: 09 Dec 2019 Location: Lincolnshire Posts: 48 |
Did lock to lock steering angle sensor recalibration after ecu reset. I can't see that the alignment would have effected the electronics? It wasn't jacked up, they did move steering lock to lock without the engine on before centrering the steering wheel? Seen a few posts which say that the CANBUS wires are sensitive... not sure where they are and there isn't anything near the tie rods that could have been knocked? Must be something in the air as my P38 is also being a dick at the moment! |
19th Aug 2021 11:57pm |
Height sensor wiring is super thin and gets very brittle! Snaps inside the plastic sheathing… Go round the car and gently pull the height sensor wires one at a time. Pound to a pinch one has broken…
20th Aug 2021 8:06am |
Took the car out today very gingerly and no warning lights or suspension issues?! So who knows what was up, car must have had a "brain fart"? |
20th Aug 2021 1:58pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Fault could have been caused by low battery voltage, if the mechanics had the doors open, etc., without the engine running it could have drained the battery slightly or enough to cause the fault. These fatties are very voltage sensitive, many's the time I've had faults pop up and disappear due to a fluctuation in battery voltage. |
20th Aug 2021 3:36pm |
Could have been a drain, battery is a recent big amp Bosch and the old gal is getting used most days? I think she was just giving me a "don't get too comfy" prod after a local F%&kwit made the "their nothing but trouble" comment last week... ironically he only drives old Italian motors! Love my L322 and "grabbing a large piece of wood" she has been very reliable with the right type of care for the last three years! Taxied friends around Norfolk a few weeks back on holiday and now their looking at getting one. |
20th Aug 2021 8:06pm |
