Home > General > Range Rover to use new type of heater
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
I must admit to having been somewhat underwhelmed by the performance of the Park Heat on my car on the few occassions I have tried to use it since January and was interested to read on the Evoque spec sheet that the heater will be something rather unusual and having its first outing in an SUV with the Evoque. It's called a Positive Temperature Coefficient Heater - and is very small, doesn't require the coolant to get warm before you get heat into the car and will probably drain the battery as quickly as Park Heat does............... It's basically a 21st century version of a domestic fan heater heater that has a ceramic element in it - which instantly gives off heat - no diesel fuel needed whatsoever
http://www.dbk-usa.com/ptc-heaters/about-ptcs 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #60240 13th Apr 2011 10:11pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
Been available at Maplins and on Ebay for ages , nice to see TATA going with he flow Twisted Evil Far to many gone...
Post #60241 13th Apr 2011 10:14pm
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Been standard on diesel golfs from at least 2007, quite good and only runs when the engine is on
Basically a heating element in an air duct so you get hot(ish) air in return for a huge alternator load
Post #60244 13th Apr 2011 10:30pm
scene247
Like the idea of having instant heat in the cabin, would be a good addition. Though I thought the park heat was also designed to warm the engine block aiding cold starting etc for diesel engine?
I also read the manual and discovered what you all probably know already, the park heat remote is also good in the summer on hot days as it works in reverse i.e. cooling the car. Guess it just starts the fans without the heater. All just based on ambient temperature. Anyway nice to know for me as didn't before.
Post #60330 14th Apr 2011 1:43pm
dan_uk_1984
It's going to be a booster rather than a standard heater though I believe?
Interestingly the freelander has used the same tech (ok not a ceramic plate, but an aux electric air-heater), since the TD4 was launched in 2001!
Post #60348 14th Apr 2011 2:53pm
jonminns
On a golf at least it runs when the coolant is below 60 degrees or so and if the heater control is set to full
Post #60415 14th Apr 2011 10:19pm
