Home > In Car Electronics (L405) > Dashcam hardwire
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Dashcam hardwire
What’s the best way to hardwire a dashcam. Just got an SDV8 2013, No suitable plugs available.
Post #603745 14th Aug 2021 7:11am
Run a cable down the passenger side windscreen pillar and into the glovebox - then piggy back fuse.
There’s some threads in the wiki - https://www.fullfatrr.com/wiki/Main_Page
And others here - https://www.fullfatrr.com/forum/search.php...rch_time=0
Post #603749 14th Aug 2021 7:53am
Kot
Some useful tips here as well
https://www.rangerovers.net/threads/how-to...up.348970/ 2018 SE SDV8 4.4 Byron Blue
Post #603751 14th Aug 2021 8:38am
madasmad
United Kingdom 2019 Range Rover Autobiography SDV8 Baltic Blue
Powerful do a kit that plugs in to the wiring loom in the centre front roof consul where the sunroof button is. Easy to put in as just plug and play. 2019 Autobiography SDV8 Byron blue/black - current
2016 Vogue SE SDV8 Santorini Black/Ivory - sold
2009 RR Sport TDV8 HSE - sold
Post #604082 18th Aug 2021 12:06pm
have you a link please. ... - .- -.
Post #604095 18th Aug 2021 1:59pm
madasmad
Apologies but just checked and they no longer seem to stock them even though I bought one not that long ago?? 2019 Autobiography SDV8 Byron blue/black - current
Post #604096 18th Aug 2021 2:12pm
Baltic Blue
I thought they did a plug & play roof kit for the L322, but I can’t find that either.
Post #604100 18th Aug 2021 3:10pm
GrandadRob
Just bought piggy back fuse link to wire the dashcam, do I just snip off the ciggy holder bit and wire into the fuse ?
Post #604340 21st Aug 2021 10:42am
nearly all dashcams work on 5volts so you need to keep the 'ciggy plug' on as it converts 12volts to 5volts.. ... - .- -.
Post #604343 21st Aug 2021 10:54am
knwatkins
You need to buy a hardwire kit.
If your dashcam supports parking guard, you'll need to connect the yellow wire to permanent 12V, red wire to a switched or ignition 12V and the black wire to ground/chassis.
The hardwire kit then gives your USB/5V out to the dashcam.
When I wired mine in, I used one of the spare fuse slots for the permanent 12V, the front accessory socket fuse for the switched 12V and the bolt just to left of the fuse box for the ground.
If your dashcam doesn't support parking guard, you just need to connect to the switched 12V and ground. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #604394 21st Aug 2021 6:29pm
