Home > Technical (L405) > A/C fans and rear diff issue?
Tizzy
United Kingdom 2015 Range Rover Autobiography SDV6 Santorini Black
Hi All
New member but long term RR owner, but this is my first L405, having had various Sports and an SVR in the past. These questions relate to a 2015 3.0TDV6 Autobiography with 57k and FSH
1. A/C fans cutting out. When working hard in the recent hot weather, for no reason the AC fans in the front occasionally just cut out. The rear vents above the rear doors stay on (well one does, the other doesn’t seem to work). Turning climate off and then on again resets it and the fans restart every time. It only happens when the fans are running at high speed on the Auto setting. Any ideas? The AC button remains illuminated throughout and the vehicle has the 4 zone climate with the separate rads etc in the boot.
2. Strange feeling best described as a bouncy hopping from the rear left wheel when pulling out of junctions most noticeable when turning right. Reading through posts on here I’m thinking this might be diff related and probably best to start with getting the diff oil changed? It has FSH all with JLR dealers, but I’m not sure they routinely change diff oils at this kind of mileage or even try to make out that they’re sealed for life!
Any and all help very much appreciated.
Many thanks
Chris
Post #603893 16th Aug 2021 8:27am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Try changing your transfer box oil, at least twice, there is a known issue with juddering while turning, even at relatively low mileage, off memory the service life for T/F case oil is 60K so your almost there anyway. Ive done a few now where its taken several oil changes to cure the issue.
Post #603957 16th Aug 2021 9:40pm
could your problem be this,
https://www.fullfatrr.com/forum/topic37809...=fuel+tank ... - .- -.
Post #603958 16th Aug 2021 9:47pm
Tizzy
Thanks for the quick responses, much appreciated!
I thought it was likely diff or transfer box oil, so am having both diffs and transfer box oil changed by my local Indie next month 🤞. It’s definitely not related to the fuel tank as the sensation still happens with a full tank.
Anyone any thoughts on the strange fan cutting out issue?
Cheers
Chris 2015 3.0 TDV6 Autobiography in Santorini Black with black-pack
2020 Evoque P300 HSE Dynamic
Past RR’s: 2018 SVR, 2016 Sport Autobiography SDV8 and an SDV6.
Post #603983 17th Aug 2021 10:41am
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
What DieselDave said ^^
I had this with my D4. Felt like a diff was locked and the wheel was skipping/bumping when pulling out of a junction with some steering lock on. Mine was worse on right hand turns
Changed transfer box oil once and it improved, did it again after a couple of weeks and it cured it Thumbs Up Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #603988 17th Aug 2021 11:20am
