Home > Maintenance & Mods (L322) > Front O/S brake shield
Squirrel
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Galway Green
Hiya,
I’ve got to try and find a replacement front o/s brake shield for my MY2010 L322, but apparently LR don’t do them any more. Any ideas where I could get one?
Cheers all! 👍
Post #603491 11th Aug 2021 3:31pm
Any good....
https://www.ebay.co.uk/itm/283561154923?fi...vJ-Ko0egRg Pete
Post #603492 11th Aug 2021 3:43pm
Squirrel
Thanks! I’m a bit worried by the review that says it doesn’t fit though.
My mechanic reckons he might be able to tack weld it if we can’t get one, not sure if that’s a good thing or not!
Post #603493 11th Aug 2021 3:48pm
If it doesn't fit it's not as described, open a case with eBay and they will send you a return label...
If yours has corroded around the fixing holes then some repair washers will sort it...
First thing you do when off roading is take them off anyway as stones get stuck, I ran fatty off roader for years without them... no issues at all.... so don't worry too much... Thumbs Up Pete
Post #603499 11th Aug 2021 4:08pm
Squirrel
Oh, you can run without them? That’s worth knowing, cheers! At the moment I’m just applying the ‘close the window’ fix - if I can’t hear it, it’s not happening. 😂
As it happens, I’ve finally managed to source one from rimmerbros.com. They seem to know their stuff, so I’ve paid up and we’ll see what happens when it gets here! Surprisingly hard to get hold of, though.
Post #603513 11th Aug 2021 4:55pm
Thumbs Up Pete
Post #603532 11th Aug 2021 8:11pm
