Home > Technical (L322) > Remote fob without a key... |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
Yes, a locksmith or auto locksmith can easily cut a new blade using your existing blade as a template. |
6th Aug 2021 9:14pm |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 |
Yep, but will they have the blank blade to fit in the 2011 RR key fob? |
6th Aug 2021 10:00pm |
If the same as in the below video, yes, standard part, nothing special.
6th Aug 2021 10:14pm |
Yep, the remote still operates the central locking. No idea how they lost the blade. |
7th Aug 2021 12:34am |
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 |
The transponder is what allows the key to turn in the ignition.
7th Aug 2021 9:53pm |
I can't quite work out which bit is the transponder but just taking the circuit board out of the damaged fob is enough to unlock and start the car.
7th Aug 2021 10:50pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
The scenario may well be similar to one I had. Lost the key, but the cost of a new one from JLR was so I bought a used one from eBay and used the IID to program it to the car. I threw the blade away and never quite got round to having a new one cut. |
8th Aug 2021 6:56am |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 344 |
The 2010+ cars don't have any option for turning the key in the ignition as they're push-button start.
8th Aug 2021 10:22am |
8th Aug 2021 10:46am |
