Home > Technical (L405) > Any info appreciated- both electric front seat not working
bigal
Hi this is my first post. I am having some problems with my L405. Neither of the fronts seats will move using the electric buttons. Have checked all the fuses. Checked what wiring I could get to under the drivers / passenger seat but can’t see anything obvious. The cool seat program is working but the massage seat program has also stopped working. Was working fine one min and then just stopped. Any help would be great fully appreciated. Alan
Post #603008 6th Aug 2021 1:39pm
spbee
A quick look at the wiring diagram would suggest that relay-comfort and fuse 8R in the rear junction box are common to the driver and passenger front seats so i would start my investigation there.
Post #603048 6th Aug 2021 7:30pm
You could try a battery reset, follow the procedure in the workshop manual, disconnect then reconnect the battery...
If no joy then get an Indy or the dealer to check for fault codes... Thumbs Up Pete
Post #603052 6th Aug 2021 8:57pm
bigal
Thank you your replies. Have managed to solve the problem with your guidance. Didn’t even know there was fuses in boot! Turned out it was fuse 8. You have saved me a trip to the dealer and potentially a lot of cost. Thanks very much fir both replies. Very happy after four days of looking Smile
Post #603100 7th Aug 2021 1:41pm
mjdronfield
That’s good then.
Fullfatrr..... resistance is futile 🤣🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #603101 7th Aug 2021 1:55pm
spbee
Glad its fixed Smile
Post #603111 7th Aug 2021 5:07pm
knwatkins
Great news Thumbs Up Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #603120 7th Aug 2021 6:02pm
Thumbs Up Thumbs Up Thumbs Up
Post #603158 8th Aug 2021 12:32am
