Home > Technical (L322) > passenger door will not unlock L322
razzer
England 2003 Range Rover HSE Td6 Zambezi Silver
can anybody help. i can't open the passenger front door. neither with the fob the lock/unlock button on the dash or by pulling up the button on top of the door. i have tried squirting WD40 down the the door button. any ideas chaps. MOT is due next week.
Post #602863 5th Aug 2021 8:47am
Marcel M6
United Kingdom 2012 Range Rover Westminster TDV8 Buckingham Blue
I had this on one of my rear doors. Door would still unlock when pulling on the door handle.
Needed a new actuator - think that's the little motor in the door that locks/unlocks the door.
About £200 done at an independent
Post #602874 5th Aug 2021 11:18am
mjdronfield
You can still open it by pulling on the interior handle though right?
I had both rear door latches on my TD6 replaced as they failed within weeks of each other.
I seem to remember something can be done if you open the rear door you can then get to something on the edge of the front door near the latch.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #602878 5th Aug 2021 11:55am
this Mark,
https://www.fullfatrr.com/forum/post328029.html#328029 ... - .- -.
Post #602879 5th Aug 2021 11:59am
mjdronfield
Yes, that’s it Stan. Luckily I’ve not had to do that.
Though if it’s a one chance thing, you might be better already having the new door latch ready for when the door opens.
Hopefully you can get in and you won’t have to smash your door card up.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #602880 5th Aug 2021 12:06pm
razzer
Thanks for the advice, got it open now.
Post #603080 7th Aug 2021 9:38am
mjdronfield
That’s good. I’d get the latch swapped or the issue resolved whilst the door is open.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #603086 7th Aug 2021 10:32am
p38arover
Australia
Or at least get the door card off! Then, if it all goes pear-shaped, you'll still be able to open the door from the inside.
The snib (sill button) is disabled when the car is locked. Pulling up on it won't unlock the door. It's designed that way. When you get the lock out of the car, you'll be able to see why.
I've replaced two door latches this year, front passenger (left) and right rear. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #603090 7th Aug 2021 11:27am
