Home > Technical (L322) > Question
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Question
Today a strange thing happens.
I turn the key and nothing happens and on the dash a message " Trans failsafe & prog". Reason? Solution?
Post #602821 4th Aug 2021 6:01pm
First thing to check is battery voltage.... Pete
Post #602823 4th Aug 2021 6:07pm
A.Pires
The battery is very good
Post #602825 4th Aug 2021 6:20pm
That's a shame, it's the usual suspect, I'm not familiar with that box so can't help, you may get more replies if you edit your first post and make the title more relevant to the issue... Good Luck... Thumbs Up Pete
Post #602845 4th Aug 2021 9:13pm
Merchy
It is possible that you have a fault with the transfer box shift motor, not 100% definite, but may be worth checking with a gearbox specialist. Found some interesting reading in the below links, at least the gearbox itself could well be ok apart from needing an oil / filter change if it has not had one yet.
https://www.lrukforums.com/threads/trans-failsafe-prog.123621/
https://axleaddict.com/auto-repair/What-Is-Trans-Failsafe
Hope this helps Thumbs Up line up some beers for a long read Whistle
Post #602848 4th Aug 2021 9:48pm
