Home > Technical (L405) > water runing from open tailgate
abuss
Switzerland 2013 Range Rover Autobiography 5.0 SC V8 Firenze Red
Hi everybody
since a few months ..when I open the upper tailgate water is running coming from the two corners on both sides....
What could be blocked and where should I look?
Thanks and regards
Alex
Post #602785 4th Aug 2021 11:38am
RRover
2012 Range Rover Westminster TDV8 Causeway Grey
I've been told on many occasions we just have to live with this problem. Mine does it - and I wonder how much this goes towards filling up the rear light clusters with rain water, so we have to drill a tiny hole in cluster lower corner to act as a drainage outlet. The gully area at the top of hatch seems to amass rainwater - but looks fairly lubed up/coated to deal with taking on the roll of a small swimming pool... hopefully! Shocked
Bloody annoying though...
I got soaked the first few times it happened... Big Cry
Post #602790 4th Aug 2021 12:09pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
I don't understand the light clusters are on the outside body edges and they are fully sealed .
The channel beside the lights run the rain water to the bottom of lower tailgate, but this is outside of the tailgate body seal.
So Iam confused how you are getting water in your lights.
There is little bit of water that drips off the upper tailgate seals when open but only small amount.
The upper tailgate is one plastic moulded piece with only couple of holes in the top edge for wiring and camera wash water hose.
Maybe check the seals around these, this might be your problem, if water a lot of is coming out of your upper tailgate.
But no water should be coming out of you lights.
Post #602862 5th Aug 2021 8:31am
RRover has a L322 and this thread is about the L405....the L322 did suffer more than the newer model.. ... - .- -.
Post #602865 5th Aug 2021 9:05am
jettec
Well now that makes sense so he posted on wrong thread . Not about L405 !
Post #602868 5th Aug 2021 10:17am
RRover
Sorry if I dropped in on the wrong category of RR - the problem seems to be a regular generic one though. I think the light cluster (well L322 anyways) join seals open up sometimes, and rainwater ingress is soon becoming. My silicone reseal didn't work.
Post #611928 7th Nov 2021 7:57pm
