Home > Wheels & Tyres > Tyre pressure sensor query
BFK66
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
I’m about to replace my tyres however the spare does not have a TPS and the fault light is on although the check spare wheel message has now gone so it could be a faulty battery or sensor on the others.
Can you switch them off individually or can you only switch of the whole lot - I ask as I’m probably going to fit GG AT3 and may need to have the spare at a lower pressure to fit hence the question about switching them off individually as the spare would be always low pressure
Thanks
Post #601908 26th Jul 2021 9:45pm
There is a setting in the CCF to turn off the spare wheel sensor, Well there is on mine so I guess yours will have it as well... you need an IID or other suitable diagnostics to change the CCF... Pete
Post #601949 27th Jul 2021 10:09am
BFK66
Ok thanks for your help
Post #601959 27th Jul 2021 11:07am
