Home > Maintenance & Mods (L405) > Hev 400e - uneven idle and jerky acceleration in petrol mode |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 357 |
Do you use E10 petrol? There are reports if it breaking down over time and clogging fuel pumps and filters. It is also hygroscopic so could have taken in a lot of moisture. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
25th Jul 2021 9:38am |
Phev19 Member Since: 20 Jul 2019 Location: Toensberg Posts: 12 |
I always use Shell V-Power Nitro+ unleaded fuel which should not contain ethanol. |
25th Jul 2021 9:47am |
Took the car to the dealers today. Hardly got there , but at the dealers yard the idle was smooth. The dealer suggested a thorough check if the problem should return, which it did on my way home. Problem persisted on may return to the dealer , in addition the engine fault light came on. The dealer now realised how serious the problem is and took the car in for check. |
26th Jul 2021 1:43pm |
Update ! Apparently the fault is caused by camshaft Adjuster Solenoid/Oil Control Valve failure. The dealer had the same fault in an identical car two weeks ago. Waiting for spare parts, temporarily fixed. |
27th Jul 2021 2:00pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 769 |
I had the uneven idle in 2020 and a software update fixed that. They said that, while charging, it is normal that the idle is different from the non-charging idle...
27th Jul 2021 7:18pm |
