![]() | Home > Technical (L322) > 4.4 TDV8 Plenum |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Have you cleaned it ?
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Hi Mike, it had a misting of oil prior to me wiping it down and the misting leaves a deposit on the oil filter cover which I would expect if air was being blown out if the seam 2011 TDV8 Vogue SE |
High pressure smoke test is the only way to be 100% sure, but I suspect it is split from your reply.
It would make sense Mike I think I have the one Range Rover that is plagued by all the faults currently on your list |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Might be one of the factors causing your issues....worth making sure |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Unfortunately its quite common... But at least its easy to replace unlike the 3.0 |
Craig - what symptoms would this issue cause? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Rob,
Mike answered it for me DrRob… |
Many thanks for all the responses gents, much appreciated. I'll order up a new plenum and get that fitted hopefully this weekend. I did have a high pressure smoke test carried out some time ago (or at least that is what it was booked in for), no leaks were found during the test, however, the passenger side inlet manifold was replaced as they suspected it was cracked. 2011 TDV8 Vogue SE |
Mine does not have that sort of split in it. Checked yesterday when cleaning MAP Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
klj Member Since: 24 Aug 2019 Location: Frozen North Posts: 66 ![]() ![]() ![]() |
Hi all. Had a split appear in mine , luckily on the top. Used a good quality epoxy resin to seal temporarily . It is still there and working months later . Must get that new plenum ordered.... ----------------
@kij
