Home > Maintenance & Mods (L322) > Torque settings on chrome wheel nuts on 20" alloys
kenneally_mark
Ireland 2012 Range Rover Westminster 4.4 V8 Santorini Black
Hi,
I'm looking to see what torque settings is recommended on: chrome wheel nuts on 20" alloys
Thanks
Post #601260 20th Jul 2021 1:49pm
for standard landrover 23mm shank nuts its 140nm or 103lb..
all in the WM Thumbs Up ... - .- -.
Post #601263 20th Jul 2021 2:41pm
kenneally_mark
Mighty thanks Stan!
Post #601266 20th Jul 2021 3:25pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Torque setting for nuts also in owners handbook
Stan however has swollen nuts if he is using 23mm sockets
Post #601366 21st Jul 2021 11:02am
socks? ... - .- -.
Post #601372 21st Jul 2021 12:00pm
Rambles
Auto spell check.
Socks 🧦 instead of sock....ets.
I have 22mm
Although I do have a couple of swollen ones that need changing out
Post #601396 21st Jul 2021 4:05pm
they are actually 22.6mm shank so i rounded it up to 23mm.. ... - .- -.
Post #601398 21st Jul 2021 4:08pm
Rambles
Are you using 23mm sockets then?
I use 22mm sockets.
Post #601446 22nd Jul 2021 7:41am
BlowerAddict
United States
C'mon guys, the lug nuts are actually 7/8", until the tyre shop uses a worn out 12 point socket and rotates the stainless sleeve on the 13/16" nut underneath....On a new nut, 7/8" fits perfectly (only use 6 point sockets please!
Post #601667 24th Jul 2021 4:59am
