![]() | Home > Technical (L405) > Restricted Performance |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
Have you tried cleaning the sensor ??
Mike G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
Not helping with the problem but your Gap tool needs a setting changed so that it shows all faults. For some reason the tool is supplied without the appropriate setting. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
cracked inlet manifold I reckon. Thats what I had. Always at the same spot on the M4, slight incline and little throttle required - RP!! |
madasmad Member Since: 22 Mar 2020 Location: Cheshire Posts: 85 ![]() ![]() ![]() |
Thanks Mike, let’s give it a go! 2019 Autobiography SDV8 Byron blue/black - current
Thanks Graeme, you don’t happen to know which setting by any chance do you? 2019 Autobiography SDV8 Byron blue/black - current 2016 Vogue SE SDV8 Santorini Black/Ivory - sold 2009 RR Sport TDV8 HSE - sold |
Thanks DB, if it were this should it have shown on the smoke test? 2019 Autobiography SDV8 Byron blue/black - current 2016 Vogue SE SDV8 Santorini Black/Ivory - sold 2009 RR Sport TDV8 HSE - sold |
Show faults, select advanced then ensure that failed, pending and confirmed are all ticked. |
Thanks Graeme |
It would be the 1st that I've heard of on a L405 for which the 4.4s started with a revised inlet manifold, which may have been introduced on the last of the L322 engines too as those engines had quite a few enhancements starting early calendar year 2012. |
So the sensor was cleaned but made no difference. The Land Rover technical bulletin was consulted and it transpires that the fault code is a known issue which is caused by an airflow parameter being exceeded resulting in the issues I was having. Land Rover have a software update which has been applied and the problem seems to be resolved.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
I know this is an old thread but today I had exactly the same problem, acceleration up hill then Restricted Performance slowed me down (I wasn't going that fast |
I believe it can only be done by either a main dealer or a LR specialist who has access to this software. 2019 Autobiography SDV8 Byron blue/black - current
