Home > General > £10k Budget - Advice/Recommendations on best 4x4?
Page 3 of 4 <1234>
ebajema
TJRL wrote:
garyRR wrote:
Is it a 3.6 I presume, being a 2010?
No, 4.4 TDV8, and "lowish" mileage. Rolling with laughter
Just broken in I see Rolling with laughter MY 2010 5.0 SC Galway green and sand interior!!
Post #601220 20th Jul 2021 9:11am
harleyman
Spain
Maybe I should not say this, but have you consider the Toyota LandCruiser.
Before my 4.4tdv8 I had a 2004 Land Cruiser and I have to say that it is bullet proof and maintenance is cheap
With 300.000kms I had to change the rear air suspension and it cost me 700€
And a good thing about these cars is thar they keep the value
I know it is a different type of 4x4 but it is a great car 2012 Range Rover 4.4 tdv8 Autobiography
Post #601221 20th Jul 2021 9:21am
ebajema
We had a 100 series landcruiser and it just kept needing repairs, even more then my 06 L322 SC. And it was fuel system, steering rack, AC, suspension issues. It never left us stranded but it was not reliable at all, at least not "Toyota like".
We had an Estima as well, great car but again quite some costly repairs AND left me stranded twice (duff alternator), belt tensioner (expensive !!!!), radiator (expensive !!!!).
My current L322 (see profile) just had its water pump done, the first big repair for a 11 yr. old car (the Estima and Cruiser were same age) with 179k kms (Toyotas were similar mileage). It hasn't failed me at all, it just runs (mind you, I keep up with its service).
Statistically LR products are not doing well, I think the main reason is, people skimp on maintenance and LR products just take less abuse than Toyotas. Some components in LR products are still not proper quality (turbos, cam chain tensioner guides, turbo hoses, EGRs, to name a few) but overall the quality is getting better and better. The complexity of an average LR is also much higher than a Toyota and that means more failures statistically.
If you get a L322 again (never go down to smaller models, unless you think it is too big, you won't like it I'm sure), take your time to find a good one, well serviced and well maintained, driven with car and not reckless abandon and I'm sure it will serve you well for a long time (as long as you stay on top of the maintenance.). MY 2010 5.0 SC Galway green and sand interior!!
Post #601231 20th Jul 2021 10:31am
garyRR
What's the service interval for particular parts on the 4.4?
I'm assuming there's an auxiliary belt and tensioner change at 100k and the ZF box is 'sealed for life' I.e. service before 150k?
And I'm assuming they're chain driven engines so, no maintenance needed there.
And what mileage do I want these on? Less than 100k? Less than 125k? Less than 200k? Doesn't make a difference? 2015 Range Rover Autobiography 4.4 SDV8
Post #601248 20th Jul 2021 11:48am
garyRR
T. 2015 Range Rover Autobiography 4.4 SDV8
Post #601279 20th Jul 2021 4:48pm
Slow progress
It looks brilliant.
Think you’ll get it for £11k? Supply is tight and that will sell, great spec and colour combination. Be interested to see the quality of the warranty
Post #601285 20th Jul 2021 5:10pm
mjdronfield
Yes, plenty to bargain with there. The vehicle looks honest... needs paint here and there. Looks like dent on top tailgate...
Has RSE... £2500 option....
The advert is a bit off though, the hifi isn’t upgraded and it doesn’t have the design pack.....
You ought to get more warranty thrown in.... those look like full warranty charges there. Or at least nearer to “cost”....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #601289 20th Jul 2021 5:22pm
garyRR
I think I'm mainly looking at the fact it's 2 owners and full main dealer history to Jan 2020, of which he's sent me photos of the service book and print out of works from JLR.
Oil cooler seals were done in 2017. 2015 Range Rover Autobiography 4.4 SDV8
Post #601290 20th Jul 2021 5:25pm
mjdronfield
Just cosmetic stuff to get as you like it then.
I like the colour combo...
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #601292 20th Jul 2021 5:37pm
kevinp
I had a Ford Explorer for 17 years and it towed my caravan and horse boxes out of muddy fields with no problem. Worth a look?
Post #601295 20th Jul 2021 5:51pm
garyRR
I went and viewed this car because it sounds good but walked away:
https://www.straffordcars.co.uk/used/cars/...uto-18863/
When I arrived, the car had a flat tyre and awful I think - a load of chemotherapy paperwork of the previous owner's in the glove box. This set my alarm bells ringing before I'd even looked any further that the dealer clearly hasn't prepared the car or cares about it, despite being a reputable dealer with Porsches and Bentleys on the forecourt.
Once I'd said hello and got the keys, I started having a good look round. The tailgate strap bolt was out - I was thinking why on earth hadn't they bothered to just screw the bolt back in for sale? I also found the passenger cooled seat wasn't working, the tracking was very far out (made me think about the roll bars / suspension arms potentially needing replacing) and rather dangerous, the nearside brake pad wasn't connected to the caliper and was hanging against the hub - not even on the disc! The sunroof also wasn't closing properly.
There was also a metallic repeating sound when idling - I suspect this was the tensioner on the auxiliary belt. Also, there seemed to be a tuning box / fooling device on the airbox which was unplugged - I can only assume it's a cheap one been plugged in at some point to fool the MAF sensors.
So, in all, the car clearly hadn't been prepared for sale or inspected whatsoever so, the right decision was to walk away on this one because I can't trust that dealer and the condition was poor really, given the car is only 10 years old with 2 owners. 2015 Range Rover Autobiography 4.4 SDV8
Post #601376 21st Jul 2021 12:57pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
That's shocking Shocked I would have walked as well.
Looks nice in the pics though - obviously where the time was spent Laughing
Cheers,
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #601377 21st Jul 2021 1:13pm
mjdronfield
Wow. I would have done the same.
They need to do something to get your hard earned money....
Onwards and upwards then.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #601381 21st Jul 2021 1:31pm
garyRR
For no money off either... There's better cars out there for similar money. 2015 Range Rover Autobiography 4.4 SDV8
Post #601383 21st Jul 2021 1:32pm
garyRR
Is there a mileage I should be aiming for or does mileage not really matter on these 4.4s? 2015 Range Rover Autobiography 4.4 SDV8
Post #601385 21st Jul 2021 2:17pm
Page 3 of 4 <1234>
